Could I find a DD13 or 15 in a parts yard that is separate from a rig and buy it to rebuild??? How about an Eaton 13 speed also???
rebuilding a DD!3
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bob888, Aug 26, 2013.
Im sure you could
I would be very cautious about tearing down a transmission to rebuild it yourself. They can be very complicated and require a good 50t press to press gears off the shafts. Aswell as if you don't get everything timed up properly catastrophic damage will be the result. I have seen the countershafts out of time climb the mainshaft and rupture the case not a pretty sight.
Cheepest way is probably to by a crashed tractor at the auction. Take what you want off it scrap the rest
