Rebuilt fifth wheel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Mar 10, 2019.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    Holland fw 17 with fresh kit still has slack. Is my top plate shot. 550,,000 miles on plate
  3. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    you have to adjust them and everytime you adjust you have to unlatch and then relatch to check the slack
  4. Rideandrepair
    17,442
    56,582
    Aug 8, 2015
    Do you have the bolt with nut in front for adjustment? If so follow Holland’s instructions on adjusting. Basically loosen bolt enough that when hooked, you can still spin washer by hand if not loosen nut some more
  5. Rideandrepair
    17,442
    56,582
    Aug 8, 2015
    A better way to say it is loosen nut up hook trailer,while eased up on fifth wheel tighten nut till washer is snug, but is still able to be turned. Proper recommended way is to get “kingpin” tool, and adjust
