Recent FCC Enforcement Action
Discussion in 'CB Radio Forum' started by delta5, Mar 3, 2013.
  1. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    This just in...
    FCC Issues $10,000 Fine to Missouri Man for Unlicensed Operation on 14.312 MHz
    03/03/2013 On February 25, the FCC issued a Notice of Apparent Liability for Forfeiture (NAL) in the amount of $10,000 to Jared A. Bruegman, ex-KC0IQN, of Bolivar, Missouri. The FCC said that Bruegman "apparently and willfully violated Section 301 of the Communications Act of 1934, as amended by operating an unlicensed radio transmitter on the frequency 14.312 MHz in Bolivar, Missouri." Bruegman -- who does not currently hold an Amateur Radio license -- was operating in the phone portion of the 20 meter band that is assigned to the Amateur Radio Service on a primary basis; his Amateur Radio license expired in 2010. As a former Technician class licensee, he did not have privileges to operate in that portion of the 20 meter band when he held an Amateur Radio license.
    In December 2012, the FCC's office in Kansas City received a complaint from an Amateur Radio operator, reporting interference on 14.312 MHz. Upon investigation, agents from that office heard a male voice transmitting on the frequency 14.312 MHz. Using direction finding equipment, the agents located the source of the radio frequency transmissions to a transmitting antenna mounted on a pole next to Bruegman's residence. The agents determined that the signals on 14.312 MHz exceeded the limits for operation under Part 15 of the Commission's rules and therefore a license was required to transmit. The agents further discovered that Bruegman did not hold a license to operate a radio transmitter on 14.312 MHz at or near that location.
    The agents determined that the source of the transmissions was coming from an unlicensed radio transmitter from a bedroom in Bruegman's residence. "Mr Bruegman was the only person present in the bedroom and the only male in the residence during the inspection," the NAL stated. "Mr Bruegman admitted to the agents that he owned the radio transmitter. The agents observed that the transmitter was turned on and tuned to 14.311 MHz. Mr Bruegman told the agents that he had no current Commission licenses, but that he previously held an Amateur Radio license, call sign KC0IQN. Mr Bruegman told the agents he would remove the microphone from his transmitter and only use it as a receiver."
    Section 503(b) of the Communications Act provides that "any person who willfully or repeatedly fails to comply substantially with the terms and conditions of any license, or willfully or repeatedly fails to comply with any of the provisions of the Act or of any rule, regulation, or order issued by the Commission thereunder, shall be liable for a forfeiture penalty." In addition, Bruegman was found to be in violation of Section 301 of the Communications Act, stating that "no person shall use or operate any apparatus for the transmission of energy or communications or signals by radio within the United States, except under and in accordance with the Act and with a license granted under the provisions of the Act."
    Bruegman has until March 27, 2013 to pay the forfeiture in full, or file a written statement seeking its reduction or cancellation.
    http://www.arrl.org/news/fcc-issues...ri-man-for-unlicensed-operation-on-14-312-mhz
  3. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    The guy obviously wasn't very smart to have transmitted on a radio frequency w/o the proper license. But I guess it goes to show just when you think uncle Charlie stopped caring, somewhere he still does. :roll:
  4. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Good to hear. He must have been doing more than just QSO's and generally behaving himself...
  5. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    14MHz isn't even the CB frequency. In CBing, just don't bleed on the emergency communications or other major businesses or frequencies. If you avoid doing that, you shouldn't have any problems.
  6. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    There are a lot of "big" radios in that area of Missouri. For the life of me I can't figure out why anybody would transmit outside of 11 meters with out a license. What is the point???? :dontknow: I guess they just like to support their government!:biggrin_2552:
  7. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    i wish they would nail that SOB in TN exit 33 off I75 at the ponderosa truck stop. spamming that prerecorded message at like 3 minute intervals.....big headache.
  8. stonecold_2136
    stonecold_2136 Light Load Member
    91
    40
    Jul 3, 2010
    Lansing, Michigan
    There is a radio rambo with a big radio around exit 102 off of I-94 in battle creek michigan. He has high jacked channel 19 for as long as 4 days at a time. He insults drivers and tells tails about how much he hates truck drivers.
  9. Turbo-T
    1,953
    708
    May 31, 2009
    What's the message say?
  10. MsJamie
    MsJamie Road Train Member
    If you know of a private pilot in the area, have them report interference of aviation frequencies to the FCC. That'll get someone's interest...
  11. cadillacdude1975
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    the message is as follows........."Shell ponderosa truck stop in charleston. radio shop is open. need more power? we now have the stinger amps, bigger finals and toys. we also buy and sell used equipment. shell ponderosa truck stop exit 33 in charleston."
    the radio shop is only open at night. during the day, the message spams as follows:
    "hi. this is julie at the shell ponderosa truck stop. ponderosa is a full service truck stop and restaurant with a garage and radio shop. the radio shop is open nights only. shell ponderosa truck stop, exit 33 in charleston."
