redoing logs
Discussion in 'Trucker Legal Advice' started by just once, Mar 7, 2011.
  1. just once
    just once Bobtail Member
    4
    hobart,in
    if a company had you doing local logs for months can they now tell you to go back and do the logs that you have already turned in to them on long form
  3. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    why do they want this..??
  4. Allow Me.
    10,756
    12,531
    May 28, 2009
    Rancho Mirage, Ca.
    When you say "local logs", I think you mean basically a time sheet. As in start time and finish time, truck number etc, right ? I've never seen more than one kind of log. Sounds like they were, or are about ready to be audited and have been told to fill out regular logs. Just say, "Yes Sir, Mr. Bossman, am I on the clock when I do this"?
    Working Class Patriot Thanks this.
  5. just once
    4
    hobart,in
    don't know about audit, could be. yes it is the log where you put start and finish time, less than 100 radius. when they had me do these logs i told them it could only be 12 hours, we work 14 hours. now they tell me since it is 14 hours i have to go back and do all my logs on long form(road logs) and that is a good idea to charge them hours.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    maybe where you sign them you ought to put the actual date that you are doing them too, just to protect yourself! I think I would darn near refuse to do it without something from them in writing telling me to do it and why.
  7. rockcandy1013
    rockcandy1013 Bobtail Member
    7
    can u say logbook falsification? i wouldnt do it !!!
  8. roadrunner0152
    roadrunner0152 Bobtail Member
    33
    8
    Sep 25, 2010
    Many years ago, like 1985, I had a boss who made me redo a couple of months' logs because I never used to "bracket" the periods of less than 2 hours. What a pain. I found another job not long after that. After a stint with one outfit that was totally anal about logbooks, it's just a habit now to fill in every space and log every stop and try not to do anything that would make them want to investigate further.
  9. just once
    4
    hobart,in
    that is the second part of the question is it falsification. what kind of trouble could a person be in. how would you find out if it is going to get you in trouble thanks everyone
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    If you are staying within the 100 mile radius, returning to the base terminal everyday...you don't need to make a "road log". Especially one that will have no correlation to stops you made each day...can you really accurately do a log of the events you did one month ago...let alone more than a month ago?
    How will you go to a "road log" showing 14 hours on duty and the 10 hour break each day? If you can't be accurate on these "replacement logs" you are signing and turning in a false log...it is YOU that will get clobbered by DOT...the company will too...but YOU will take a bigger hit than the company!
  11. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    In 395.1 the 100 air mile exemption reads this way:
    (e)(1) 100 air-mile radius driver. A driver is exempt from the requirements of Section 395.8 if:
    (e)(1)(i) The driver operates within a 100 air-mile radius of the normal work reporting location;
    (e)(1)(ii) The driver, except a driver-salesperson, returns to the work reporting location and is released from work within 12 consecutive hours;
    To be able to run an "Exempt" log you have to:
    - 1) stay inside the 100 air mile radius
    - 2) return to the yard and clock off within 12 hrs
    If you are working 14 hour days as you said, you must keep regular log books.
