Reefer+Hazmat
Discussion in 'Hazmat Trucking Forum' started by Alejandrito01, Dec 6, 2022.
  1. Alejandrito01
    Alejandrito01 Bobtail Member
    Apr 29, 2022
    Ok I don't want any specific names of customers, but what type of companies generally move reefer-haz freight? By this I mean what is the general commodity moved? Also is it worth it or should I stick with dry-haz, btw tanker endorsed too.
  3. Chinatown
    Chinatown Road Train Member
    77,710
    184,206
    Aug 28, 2011
    Henderson, NV & Orient
    I hauled lots of hazmat loads in reefer trailers.
    Didn't need the reefer so turned it off.
    The benefit to pulling reefers is, that you can haul dry van loads and hazmat loads and refrigerated loads. Easy to keep the wheels turning pulling a reefer trailer.
  4. Oor
    Oor Road Train Member
    1,374
    3,538
    Jan 11, 2012
    Oil based paint.
    Or food ingredients, like gum oil.
    Think freeze protect product.
  5. Tall Mike
    Tall Mike Road Train Member
    7,676
    36,747
    Aug 20, 2014
    New York State
    Depends on how you are being paid ? If you are on percentage hauling hazmat and it pays more, then maybe yeah.. If you are on mileage that doesn't increase for hazmat, then I'd say no why bother..
    I don't know of any reefer companies that haul hazmat, sorry can't help with that...
  6. tscottme
    tscottme Road Train Member
    Can't reefer trailers keep the interior from freezing when cold weather is at hand? Maybe they use reefer trailer to not let the product get too cold.
  7. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    Yes the good part about running a reefer is you have many more options to choose from as far as freight goes, so unless you are super fussy, all you have to do is decide in which direction you'll choose to travel. The down side is though if you've carted hazmat you may be required to sweep out or wash the trailer first before reloading if your carrying chilled or frozen produce afterwards. Other cons are having a reefer running all the time, trying to sleep or effecting others sleep. Having the fuel gel up on you in colder weather in the reefer if you forget to put in the fuel additives.
  8. Tall Mike
    7,676
    36,747
    Aug 20, 2014
    New York State
    Yes, they are capable of heat if that's what you are asking.
  9. GreenPete359
    GreenPete359 Road Train Member
    2,246
    5,400
    Oct 21, 2017
    Driving my recliner
    Used to haul stuff from an ice cream manufacture that was haz. Had to keep it set at -10°.
    Also hauled chemicals that had to be kept refrigerated due to extremely low flash points.
  10. Steve357
    Steve357 Bobtail Member
    14
    34
    Jun 3, 2019
    Yes, like said above.....alot of products need protection from freezing
  11. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    For instance I haul (5.2) UN3109 Liquid Organic Peroxide which a low flash pointm I transport it in a refer, not freezing but kept down around set between 65 -90 degrees. The flash is around 140, only of concern during summer months.
