Reefer Ice Cream Loads
Discussion in 'Ask An Owner Operator' started by Mr. PlumCrazy, Nov 1, 2011.
  1. Mr. PlumCrazy
    Mr. PlumCrazy Road Train Member
    1,341
    606
    Jul 30, 2009
    Lexington NC
    Ok I am hauling my first Ice Cream load today. Had ever touch them loads because i was unsure of my unit and trailer (SB210 Spacesaver) and the fact that some driver say running at -20 is hard on the unit. I started it about an hour and a half ago and was suprized that it is down to -20 already. I had though about hauling it before because the rates was real good. Reason I took this one was it loads at 10am come off at 8:30pm and pays $9.24 a mile I was wondering what others thought about hauling Ice Cream and the do's and don't. I put paper towels inside plastic shopping bags and pluged my drains
  3. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    If you're nervous and have the time, sit for an hour at the place you loaded it to see how well the until maintains. That way if there are unit issues, you can back right back in instead of having a cargo claim. But I doubt you'll have any problems.
    You arent sitting in Madison Wis at Schoeps are ya?
    Mr. PlumCrazy Thanks this.
  4. wichris
    wichris Road Train Member
    4,482
    9,247
    Jan 17, 2011
    Nothing wrong with ice cream. More expensive when the weather is warmer. If you haul out west(high elevations)follow routeing if it's coated. If you need to plug the the drains the unit/trailer is in need of serious work.
  5. Mr. PlumCrazy
    1,341
    606
    Jul 30, 2009
    Lexington NC
    No in Sandston VA, I have been sitting here about 30 min with it running at idle or low speed haven't kicked back to high
    No blocked drains to keep cold air in hot air out less work on unit I always block them when hauling frozen dont need to drain trailer and unit dont have any problems it just not spec for ice cream
  6. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Read the weather report on the route. I know mine will pull an 80º drop without issue, and I still will avoid ice cream loads unless it will be <50º outside and preferably overcast. I had a broker sneak a couple pallets of ice cream at the last stop of a multiple pickup once (other cargo was just regular frozen stuff @ -10º) and it was accepted with no issues. Temps were no higher than 60º and it was overcast/raining the whole trip.
    Cargo volume makes a huge difference too. A full TL pre-cooled will buy you a lot of leeway versus a lighter load. Saved our bacon on a reefer breakdown a while back.
  7. freebirdrfd
    freebirdrfd Light Load Member
    271
    63
    Oct 8, 2011
    Raynham Ma
    Pluging the drain holes has nothing to do with how well the unit/trailer is.
  8. wichris
    4,482
    9,247
    Jan 17, 2011
    If you're plugging them for better cooling there is a problem. You have 3000+ cubic feet of trailer,the unit puts out over 3000 CFM and a few square inches of opening. A two year old trailer will leak more than that from the doors.
  9. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    I always plug my drains on frozen loads too. I am very leery of hauling ice cream in the summer time. My trailer is a little older and trying to maintain 120 degree temp difference in the summer in Texas worries me. I have and will haul it in the winter and have had no issues.
  10. Mr. PlumCrazy
    1,341
    606
    Jul 30, 2009
    Lexington NC
    Well I had no issue ran it on cycle only went into high speed a couple times
    What kind of trailer do you pull common sense will tell you if you plug the drains it will help keep the cold air in and the hot air out putting less work on the unit it dont matter if you have a brand new trailer or a 50 year old trailer
  11. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    So explain to an old machinery hauler that knows nothing about plugging vents and reefer trailers in general why it is bad to plug the vents.
