Reefer info?
Discussion in 'Experienced Truckers' Advice' started by joesmoothdog, Aug 20, 2014.
  1. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    Been mostly a guy in the weeds on this excellent resource. Smartassed occasionally, but a reader mostly, so I rarely ask for help. Humbly, I do now. Just quit Swift and off to Marten. I only know dry van. Any info on reefers op would be greatly appreciated. My bud tells me it's easy. Told me the same thing about driving a truck. One outta two would be great.
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    Set the temp to what it says on the BOL, make sure the tank has fuel, drive to destination. It's that simple.
    "semi" retired Thanks this.
  4. High H2O
    High H2O Bobtail Member
    12
    Aug 20, 2014
    texas
    Well I have a little knowledge about them is it easy yep all you have to do is keep fuel in it and look in your mirror for the green light. There maybe a few other things to change in your daily routin that freight haulers don't care about. Like almost everything in that trailer when that little engine is running is time sensitive has a short shelf life when you get a load your almost always late before you start. Then theres produce season little sleep and has a shorter shelf life than what you delivered. Be patient the shipper knows your there and so does the receiver. They will get to you sometime and the more you bug them the longer it might take them. ALWAYS GET PHONE NUMBERS TO SHIPPERS AND RECIEVERS AND CALL THEM . Don't rely others are usually wrong and have your own numbers for lumpers shippers recivers sometimes they are handy to have. You might need a favor and they might help you out.
    Ok Thats enough for now anything else holler
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Hope you enjoy driving in the dark ... :biggrin_25525:
    tangerineGT Thanks this.
  6. Powder Joints
    7,973
    8,368
    Sep 25, 2007
    Rosamond, SoCal
    Precool your trailer/ A refer is designed to maintain temp not cool down the load, check loading temp of product, if warm call in before you except the load, write loading temp on BOL.
  7. Allow Me.
    10,762
    12,560
    May 28, 2009
    Rancho Mirage, Ca.
    And enjoy sitting /waiting for your load to "cool". (10 hrs)
  8. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,909
    53,404
    Dec 8, 2012
    hunting...../ retired
    I do know one thing....we used to back-haul meat sometimes...our trailers had to be at 0 to -10 before they would let us back to a door....
  9. buzzarddriver
    3,803
    11,415
    Feb 1, 2011
    Dallas, TX
    They will explain what is expected during orientation. While they can't cover every situation, you will learn what is required.
  10. High H2O
    12
    Aug 20, 2014
    texas
    Around 48DG before they will load thats an aaverage. Now hotter the day longer it takes
