Refrigerator freezer size
Discussion in 'Ask An Owner Operator' started by Dino soar, Mar 1, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    There are a lot of threads on refrigerators and freezers but they all say the use a dorm size fridge or something like that. Almost none of them list the cubic foot size.
    What is the cubic feet of the refrigerator freezer that you guys use? And what size can I use if I take the front seat out?
    I Would imagine one that's too large would draw on the batteries too much but one that's too small would not be useful.
    What do you use? Brand model and size would be helpful.
    Wasted Thyme Thanks this.
  3. The Crossword Trucker
    The Crossword Trucker Road Train Member
    1,172
    2,333
    Feb 21, 2015
    I used to have a 4.3 where the passenger seat should be.
    Better to use a pure sine inverter if its your truck but a modified sine wave will do the job.
    Bigger ones do not really seem to use much more power.
    Check the yellow tag when you buy one and it will show you which ones are more efficient
    I like to use gorilla tape to hold the door shut
    Reason for edit: Freudian slip
    feldsforever and Dino soar Thank this.
  4. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Um where do you sit to drive? :eek:
  5. Chinatown
    Chinatown Road Train Member
    77,726
    184,292
    Aug 28, 2011
    Henderson, NV & Orient
    on the refrigerator.
  6. The Crossword Trucker
    1,172
    2,333
    Feb 21, 2015
    Well the passenger seat area has the kegorator so I had to improvise
  7. Brandt
    Brandt Road Train Member
    4,624
    6,358
    Sep 17, 2012
    They make some low voltage fridge freezer for camping but they are really expensive. They are made for real off road camping. Dometic is one, there are a couple other brands. Your looking at $700 and up. They can run on 120v or 12v they can run for days on 12v because it they have a special compressor. Dometic used Danfoss compressor. I read they make their own now but those Danfoss compressor are made for low voltage. You might not want to that much into a fridge. It's interesting to see how they can be made to last a long time and use less energy.
    86scotty and Dino soar Thank this.
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    4.1cf Frigidaire. It has a lock on the bottom of the door which is perfect for some of the roads and lots you'll go through. My only gripe is that the freezer is unreliable and it doesn't matter if the truck is running or not. Either nothing freezes or the entire fridge might ice over.
    feldsforever, Dino soar and 77fib77 Thank this.
  9. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    I have one of the off road versions mentioned and it was expensive. However, it is about 10years old now and still going strong. What I'm thinking of doing when I redo my sleeper is put in a larger dorm fridge in. Then take out the passenger seat and put in a small deep freeze chest freezer. That way I can load up at Costco cheap.
  10. 86scotty
    86scotty Road Train Member
    4,700
    12,899
    Aug 27, 2017
    Appalachia
    As good as these are I'm not sure why anyone uses anything else. Mine is 4.6 cu.ft.
    Home : TruckFridge- Americas Leader in Semi-Truck Refrigerators
    Right off 75 in Georgetown KY, east side behind the Pilot. They will install. I used to install them in campers I built, rebuilt. I've probably had 10 or more. Never had one fail.
    Mine is a T130, had to modify cabinet to fit but will fit weeks worth of food. Half gallons/2 liters fit in the door. Doesn't bother my batteries for about 5 days.
  11. The Crossword Trucker
    1,172
    2,333
    Feb 21, 2015
    Is it my imagination or has the price of those TF units really come down?
    I remember them as very expensive
    HoneyBadger67 Thanks this.
