Regear for MPG?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Blu_Ogre, Sep 8, 2013.
  1. Blu_Ogre
    Blu_Ogre Road Train Member
    8,456
    50,465
    Jul 14, 2013
    Out west
    Truck:
    2008 KW T660
    Cat C15 Acert
    10sp manual OD trans
    Dragging a refer all the time near gross weight.
    Current rear ratio 3.55
    Currently Averaging about 5.8 MPG cross country miles (Calif to Ohio and back, I-40 or I-80 about the same)
    I tend to run 65 to 70. Upper end of recomended operating range is 1400 or so rpm. I am normally above 1400 RPM by a significant amount.
    Should I expect improved fuel mileage going to 3.08 or lower number gear?
    If so how much change would be reasonable to expect?
    Is there another option, other than slowing down, to improve fuel economy?
    dude6710 Thanks this.
  3. BigJls1
    BigJls1 Medium Load Member
    482
    415
    Dec 25, 2012
    13 speed will probably help more than a gear change. Plus will really help with resale. If you swapped to to 3.42 or 3.36 that 10 speed will probably cost you mileage unless your really light loads. getting up to speed on long grades will take its toll...Id guess a trans swap would cost similar too. most likely the ratios of OD will be close so there wont be any difference in rpm but youll be about half the drop in rpm between shifts..just my option, others with a lot more CAT experience should trump any of my opinions.
    Blu_Ogre Thanks this.
  4. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    Go read some of the articles Pittsburg Power puts out about gearing, I think they are working on a plan of put a 2.64 or similar in a truck with an 18 speed and then just not using the overdrive gears.
    I think if you gear it too low, with the OD, it will lug the motor and actually hurt your milage.
    Mr. Haney may have some knowledge on this also.
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    You would probably be money ahead to trade it off and buy something set up better for what you are doing. The optimal gearing for an Acert is 3.36 with a 13 or 18spd.
  6. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    There are tons of options to improve MPG. Kevin Ruthiford has a lot of info on this topic, but there are a lot of small cheap things you can do before going for a gear swap out. Running in a 6x2 config with a 2.64 gear ratio will allow you to use trailer tires on one set of drives and drives on the other. This will decrease rolling resistance and resistance form 2 difs. That configuration will also allow you to run your trans in direct, not OD to decrease trans drag. Yes a better gear ratio will help, but exhaust all your other options first since this is pretty pricey. (at least that was KR's advice to me)
    Pittsburgh Power mufflers (.5 mpg) about $300 bucks for 2 and even cheaper if you buy the one not re branded by PP. BY FAR THE BEST 300 YOU WILL SPEND
    Fass System. (.33mpg) $685 also available at PP, but probably cheaper else ware.
    Airtabs. (unknown) Yes they look stupid, but they certainly decrease rain on mirrors and stability in wind, so they must be doing something. $200
    Supper Singles (.5+mpg) ~$4000 Dont know if you have a problem with Singles, but my Xone Line Energy D's save me .5-.75 over the duels I was running. Please don't start a debate on suppers vs duals, but I like them. The fuel saving pays for all the negatives imo.
    Wheel covers (.1-.2 mpg) $200 These are what you see on shnider trucks. They cover your wheels to help your aero
    Micro Blue bearings. (.4 mpg) $950
    KR Scangadge (up to 30%) $185 Shows life info on how much your spending, average mpg, average over last 8 sec....helps you see how to drive more efficiently.
    Side skirts on truck (>.5mpg) Varries
    At 70 MPH aerodynamics are hurting you more then the drive train or anything else. Making sure your truck is as aerodynamic as possible is important. A few hundered pounds of chrome may look nice, but every pound counts on those up hills. Also leave your tires chains home when not in season.
    Do you own the trailer? If so, Aero flex skirts save about 7% fuel and tail cones save 4%. $4000 investment for both. Singles on the trailer will save .3-.5mpg.
    I know you don't want to hear this, but running 65 instead of 70 makes a huge difference. Obviously on a 3000 mile trip this adds about 2 hours to your trip, but if you get 6.3 instead of 5.8 mpg, you would save $163 @ 4/gallon. Wow that's not as much of a difference as i thought. For 163, bucks, keep the hammer down lol. (it would be worth a try to see how much of a difference it actually makes) Also, try to take min fuel possible over the rockies. If you can take 200, and only take 100 over, that's an 800 pound savings going up those hills. All aluminum wheels helps a little to.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Yea if he changed the rear gearing I'd want to upgrade to a 13 or 18. Either would work just fine, although the 18 has a lower low for getting off the line. In any case with a 2.64 you would run in whatever gear is dirrect. On a 10 speed though, i wouldn't want to loose the extra gear. On a 13 or 18, its not so bad. One thing i didnt mention is switching to bigger tires. Much cheaper then a gear change and gives the same effect.
    cetanediesel Thanks this.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    What are we talking here, whats your rpm at 65 and whats your rpm at 70.
  9. Blu_Ogre
    8,456
    50,465
    Jul 14, 2013
    Out west
    I agree... The plan is to pay it off in a year or so and trade it off.
  10. Blu_Ogre
    8,456
    50,465
    Jul 14, 2013
    Out west
    Will check the PP site. I need to keep the DPF and other emisions system as I am Home base Cali.
    Super singles are currently on the truck.
    Was looking at the wheel covers. Ordering some next settlement.
    Micro Blue Bearings... Will check them out.
    KR Scan gauge Peoplenet computer has the instantaneous and average MPG on the safety mode display.
    Has Factory Side skirts.
    Do not own the trailer but am pushing the folks I drag it around for to buy skirts to give us all a raise. Besides Cali will be requiring them soon I think.
    Also going to try out those stick on aero tabs on extensions for my factory extensions. I have too much gap between sleeper side extensions and trailer when anywhere near gross weight.
    On slowing down: That extra 2 hours drive time can equate to extra 12 hrs to deliver. 2400 to 2600 mile run = 4 drive shifts+ 3 sleep shifts. Extra 2 hours drive time could require extra sleep cycle
  11. Blu_Ogre
    8,456
    50,465
    Jul 14, 2013
    Out west
    Will verify exact numbers when I go out in a couple of days. I do know the rev limiter settles in @ 72.
