Reitnouer Flatbed 48'
Discussion in 'Flatbed Trucking Forum' started by DechkoTzar, Aug 7, 2016.
  1. DechkoTzar
    DechkoTzar Light Load Member
    70
    28
    Apr 26, 2015
    I'm looking to buy a used 2007 Reitnouer 48' flatbed trailer. Here is the link to it: http://www.truckpaper.com/listings/...2000786014&sfc=1&ssc=1&src=0&sps=0&ftr=0&if=1
    I have noticed that the rear axle is not spread all the way to the end of the trailer like other (most) flatbeds. There is like 2-3 feed hanging behind the rear axle. Does this affect distribution of load? How do you properly distribute 48k lbs load on this trailer?
    Also, if anyone is willing to explain the specifications:
    90,000 lbs GVW
    60,000 lbs in a 10 foot section
    50,000 lbs in a 4 foot section
    What does this actually mean?
    Thanks in advance for your opinions!
    Lepton1 Thanks this.
  3. Army91W
    Army91W Heavy Load Member
    751
    733
    Nov 3, 2006
    San Antonio, TX
    Looks like an old prime trailer.
    When I worked at Melton they said the axles were set forward for some bridge law (California and CT come to mind.).
    As long as you load from the center i didn't notice any different then when the axle was all the way back.
    I know it's a 48 but on a 53 when the axles are set forward its real easy to over load the rear axle if you put much weight passed the rear axle.
    DechkoTzar Thanks this.
  4. Army91W
    751
    733
    Nov 3, 2006
    San Antonio, TX
    Means the trailer is good for 90k as long as you don't put 60k in less then 10ft or 50k with in 4ft.
    New Mexico probably the only place you could get close to scaling 90k legally.
  5. Chewy352
    Chewy352 Road Train Member
    1,797
    11,620
    Dec 17, 2013
    Enid, OK
    @TripleSix you'll be able to explain it better then I could.
  6. DechkoTzar
    70
    28
    Apr 26, 2015
    Sorry, but I didn't really get this. Let's try this way: if I have a 48k lbs load that is 10ft long, does this specification really matters? Do I just start loading in the middle of the trailer?
  7. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Get a big coil and you'll see real quick what your CLC is.
  8. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    If your tare weight is light enough you could scale 90,000 in Ohio with coils.
  9. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    It means Excactly that. 90000 over the whole deck, 600 00 in 10 ft of deck and 50000 in 4 ft of deck space.
  10. Army91W
    751
    733
    Nov 3, 2006
    San Antonio, TX
    You would be within the specs of the trailer because you were loading less then 60000lbs in ten feet.
    Until you are comfortable with your truck/trailer combination it's best to center load. Once I'm comfortable with a truck and trailer I'll start having the load placed closer to the truck because having more weight on the drives generally gives you a better ride going down the road.
  11. Espressolane
    18,662
    116,924
    The specs on this list a coil package.
    The Gross Weight for the trailer is 90K, The specs listed state the trailer is 9100 Lbs, giving you a payload capability of 80,900 Lbs, loaded evenly over the entire trailer. With the coil package, extra cross members and supports have been placed in the center 10 to 12 feet of the trailer. Thus you can load up to 60,000 Lbs evenly in this center 10 feet, and up 50,000 lbs in the center 4 feet of trailer. This is all based on the load center of the trailer. It should be marked on the frame. As to loading this trailer. Its loads just like any other 48 foot flat. should have no problems with it.
