Relocating batteries
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jan 9, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    I have been looking at some tandem dump trucks to add a lift axle and make a tri axle.
    Most of these trucks the bed is in the 15 ft range. There's plenty of room to put a lift axle, but the hydraulic Reservoir and the batteries need to be relocated.
    I have a hydraulic reservoir from another truck that mounts behind the Hoist so that would be off the frame. So that leaves the batteries.
    Is there someplace else that I could relocate the batteries?
  3. AModelCat
    164,023
    Kenworth has a factory option to locate the battery box in-between the frame rails, behind the cab. Could always try and find a used box that'll fit in there.
    Dino soar Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Western Star could be spec’d with the batteries in a box as the base of the passenger seat. Definitely no air ride seat, and the battery box is vented outside.
  5. Dino soar
    4,813
    27,058
    Dec 8, 2017
    That's an excellent answer thank you.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    If you go that way, best to use sealed acid free battery (AGM) in case of rollover.
  7. jimbo47
    jimbo47 Light Load Member
    102
    140
    Mar 4, 2013
    southern MB
    AS above PLEASE PLEASE use sealed acid free if in cab! ,its not a joke when you have to hear a friend screaming when he laid it on its side and the juice was dripping down on him till we kicked the screen out to get him.
    spsauerland and uncleal13 Thank this.
