Removing sleeper extenders
Discussion in 'Peterbilt Forum' started by onetime42, May 4, 2021.
  1. onetime42
    onetime42 Light Load Member
    172
    114
    May 20, 2009
    Mobile, AL
    I currently own a 2007, 379 extended hood and I want to remove the sleeper extenders from the 63" stand-up sleeper. My question is, I can probably remove them but I need to know if I can simply fill in the missing rivet holes with rivets using a cheap 3/16 air hydraulic riveter from Harbor Freight? The gun is only $50 and seems like it should solve my issue unless I'm missing something? Or should I take the alternate route and just buy a sht load of 1/4 inch flat headed bolts to use in place of the old ones?
  3. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    JB weld, sand and paint?
    onetime42 Thanks this.
  4. onetime42
    172
    114
    May 20, 2009
    Mobile, AL
    So don't bother filling in the holes with rivets? I know when it comes to removing that big fiberglass piece at the top corners that'll require a visit to the body shop but I was hoping to save a few bucks by filling in those holes with rivets.
  5. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    I'm not sure that rivets are waterproof
    Bean Jr. Thanks this.
  6. onetime42
    172
    114
    May 20, 2009
    Mobile, AL
    I would add some silicone in the holes prior to installing them. I just want some advice from someone that has done this project before so I don't screw it up.
  7. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    You need to use something in those holes. It holds the sleeper together. I just used rivets. If you want you could sand the rivet a bit and fill with bondo for a smooth look or just sand and heavy paint. On the bunk I did it was NOT painted under the fairings FYI
    Bean Jr. and onetime42 Thank this.
  8. spindrift
    spindrift Road Train Member
    3,234
    12,915
    Dec 2, 2014
    Texas
    Just curious is all. Why do you want to remove the extenders?
    onetime42 and Dave_in_AZ Thank this.
  9. onetime42
    172
    114
    May 20, 2009
    Mobile, AL
    I've never liked how they look and just want them gone. It's a much cleaner look too.
    Bean Jr. and spindrift Thank this.
  10. wore out
    wore out Numbered Classic
    17,310
    214,806
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Personally I think rivets look trashy. You can pick them out from a 100 feet and see there different. I realize you have to pull the interior to install huck bolts but since the job is about looks isn’t it worth doing right?
    when the rivets go to leaking how will that make it look?
    Bean Jr., Roger McG, spindrift and 2 others Thank this.
  11. onetime42
    172
    114
    May 20, 2009
    Mobile, AL
    Go 4 floors up and read what I was planning on doing when installing them so they don't leak. I'll probably end up using huck style bolts then and removing the interior to do it right.
