REPLACE EVERYTHING MY AC STILL NOT WORKING :(
Discussion in 'Ask An Owner Operator' started by Backendboyz, Aug 9, 2023.
  1. Backendboyz
    Backendboyz Bobtail Member
    7
    10
    May 2, 2023
    Hey I have a 2019 Peterbilt 579
    I replaced the relays , ac compressor, and drain system and recharged Freon
    every time I take to someone they say their is no leaks… and just put more Freon
    I pay them $3-500 just to add a lil Freon and they say it’s nothing wrong w my truck
    then I leave my ac blows cold as ever for a day and then the next day after driving for a minute my ac stops working again
    does anyone have any advice
    77fib77 and austinmike Thank this.
  3. Ridgeline
    22,717
    122,814
    Did you take it to the dealer and have them look at the cab/body or the Ecm to see what's going on?
    replacing parts without knowing what's happening with the controls is a waste of money.
    77fib77, AModelCat, austinmike and 2 others Thank this.
  4. 201
    201 Road Train Member
    12,736
    26,193
    Apr 16, 2014
    high plains colorado
    If it's any consolation, if you can hold out, in another 2 months, attention will turn to "no heat". Clearly a leak in the system and a competent mechanic will find it. It's not the space shuttle.
    77fib77, austinmike and Numb Thank this.
  5. JB7
    JB7 Road Train Member
    1,001
    1,763
    Dec 13, 2022
    Laurel, MD
    When the 'a/c stops working' does the a/c compressor clutch still turn? If not it would be due to low refrigerant or electrical whether that be wiring, a sensor/switch, or a module.
    4 ways to find an a/c leak
    1 - it will be oily where there is a leak
    2 - after the system is pumped down/evacuated/vacuumed the pump is turned off along with the gauge and then monitor to see if the vacuum drops. This will only tell that there is a leak but not where.
    3 - flourescent dye in the system
    4 - a refrigerant leak detector
    Opendeckin Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    12,798
    53,514
    Mar 4, 2015
    How many pounds of freon are they recovering before they charge the system? If it’s less than your system requires then you have a leak.
    Are you running it on auto and setting the temp or are you running the fan and temp manually? If you can verify that you 100 percent don’t have a leak and all the mechanical parts are functioning as they should then you’ll have to have someone check out your cab control module.
    Magoo1968 and Siinman Thank this.
  7. Antinomian
    Antinomian Road Train Member
    2,170
    3,440
    Feb 17, 2013
    Any missing freon means there is a leak.
    77fib77 and Siinman Thank this.
  8. Brandonpdx
    Brandonpdx Road Train Member
    4,687
    4,767
    Dec 27, 2007
    Elkhart, IN
    Could be a lot of issues they are either ignoring or are too stupid to check. troubleshooting wonky A/C can be a bit of pill but not typically on vehicles this new.
    Check the FRONT of the radiator and all other heat exchangers in the way of it are clean. The fan should be able hold a shop rag sucked against the front of the A/C condenser if nothing is plugged up, assuming the clutch is working right, which brings you to the next item on the list to check...the fan clutch. Make sure it is also working.
    Theoretically they could be telling you the truth that "nothing is wrong with your A/C and there is no leaks". I assume most shops know how to draw it down and vacuum test an A/C system and then recharge it properly, and the orifice tube and accumulator should have also been replaced if the compressor was, but you might want to go back and review that with the shop that replaced the compressor.
    77fib77 Thanks this.
  9. Brandonpdx
    4,687
    4,767
    Dec 27, 2007
    Elkhart, IN
    I wonder if the space shuttle had air conditioning...
    201 and Nostalgic Thank this.
  10. Nostalgic
    Nostalgic Road Train Member
    1,815
    20,015
    Mar 6, 2017
    PA
    I really don't want to dive into the whole flat earth thing, but with what it takes in 2023 technology to keep a semi sleeper comfortable for 8 hours with just a 40-50 degree differential, I'm starting to wonder about any of the space shuttles and stations. How efficient was solar and batteries in the 60's?
    singlescrewshaker Thanks this.
  11. Ridgeline
    22,717
    122,814
    ouch!
    I suggested looking at the computers that run the a/c, to see what they see and if there is an actual leak or there is a sensor or even a computer problem. It could also be a high condenser temp because of a clogged radiator or crap between the two.
