Replaced injectors
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tsavory, Jul 31, 2015.
  1. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Ok I am at a shop that just replaced 2 injectors when they got done start up sounded terrible but it leveled out after a bit. They just ran it up the road and each shift seen the white smoke just rolling.
    Upon pulling back in its still smoking is this normal?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Should burn off. Once you get some heat in it .
    Just exsess Fuel and oil in cylinder burning off.
    KB3MMX Thanks this.
  4. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    You also have air in the system that will take a while to get out.
  5. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Ok just figured if it was burn off an hour idle and a we min drive would have cleared it up but had not. But 50 miles down the road after leaving all was clear. Thanks guys for the response.
    Ruthless and MJ1657 Thank this.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    sounds like me, if everything is not right in 30 seconds, alarm bells go off. :biggrin_25523:
    tsavory and taxihacker66 Thank this.
  7. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Yep but something still is not right it idles rough every now and again the fuel mileage dropped and it slightly jerks if I get above 1500 in gear but don't blow white smoke anymore just the normal black. Will be near home area tomorrow and have it hooked up to a computer. Called the shop that got it going again asked about symptoms they just said no clue get ecm read. Sounds promising. NOT!
    At first thought I was imagining it but the guy that changed a flat said it sounded rough when I pulled in but before I left it sounded fine.
  8. QUALITYTRUCK
    1,818
    1,783
    Jun 14, 2009
    romulus,mi
    Engine? Proper injector height adjustment is usually not done by some places after replacement.
  9. tsavory
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    That's what I am thinking. Just not right after you drive your truck for a while you can just feel and hear when something goes amiss. Like the tire it did not blow just lost the air from a seam and just felt weird and the hum of the tires was off.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    there is a real good post about your exact problem, and how to fix it but it is not allowed on here. will try to find it & get to you if possible.
    tsavory Thanks this.
  11. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    I had the white smoke once, turned out 2 wires going from the ECM toward than fan were not in place and slightly burned.
