Restroom access
Discussion in 'Shippers & Receivers - Good or Bad' started by driver81, May 23, 2017.
  1. driver81
    driver81 Bobtail Member
    47
    6
    Feb 6, 2013
    I had made a delivery to a customer which is at a plant , and they only had one portapotty for the drivers with no running water to wash your hands. Now I made deliveries to the same company at different locations, and they either will walk you to the restroom or you can just walk right in for the drivers. Are restrooms required for anyone making deliveries? This is the first time at a big plant that had no restrooms with running water for drivers.
    KB3MMX Thanks this.
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    ...and it won't be the last
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    Purchase a chemical toilet for camping purposes into your sleeper with the necessary disposable materials etc. The water you will have to purchase by the case and take care of manually for yourself.
    In other words the plants no longer allow drivers free roaming into restrooms.
    The last time a plant allowed me to access, the migrant workforce considered me a intruder and treated me as such. Since it was a meat plant with knives of all kinds (Some were chained to tables etc) it was a rather dangerous evolution.
    Plan your arrivals to the plant having eliminated the necessary waste prior.
    It's crazy and some times bordering on inhumane but times have changed quite a bit. And not without cause when you consider what outside drivers sometimes did to the plant's facilities.
  5. tinytim
    tinytim Road Train Member
    5,145
    19,039
    Oct 29, 2007
    Northern Ontario
    No.
  6. 28
    28 Medium Load Member
    692
    47,882
    Sep 17, 2015
    I recall this was common in California
    Drive all night ...get there ...and no facilities
    Confirmed with the state that they do not have to
    provide anything for drivers ( or anyone that doesn't work there )
    rabbiporkchop and KB3MMX Thank this.
  7. Mullet_Head87
    Mullet_Head87 Medium Load Member
    453
    548
    Apr 19, 2014
    Clearwater
    Funny I'm reading this in a porta potty right now. I have Clorox cleanup wipes I use at every toilet. Most don't even need them but there are times I have to wipe away poo,wee wee and butt grease from swamp ###. Some guys have a huge arse and always leave a streak at the top center of the rim. If your gonna be sitting for 18-20 a porta potty is a blessing, just have to clean it up a bit. Also carry thick wet wipes to avoid fingers breaking through the thin paper resulting in Mud Mitts. Hand sanitizer with alcohol and aloe to clean up. Don't Care if it has alcohol in it, I'm not drinking it like the Inuits in Alaska.
  8. DUNE-T
    DUNE-T Road Train Member
    7,034
    17,109
    May 10, 2015
    Detroit, MI
    Carry a soap in your truck and wash hands after using portapotty
  9. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
  10. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
    Many companies are fed up with messes, vandalism, and graffiti until it gets to this point.
    p608, KB3MMX, Crude Truckin' and 4 others Thank this.
  11. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Carry Babywipes...
    rabbiporkchop Thanks this.
