Reuse axle gaskets?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 13, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I may have to pull my axles out in the near future.
    The gasket that goes between the axle flange and the Hub, can that be reused or is that something that you replace every time you service the hub?
  3. AModelCat
    164,522
    I'd replace. Its rare any gasket comes off in one piece and after they've been crushed they likely won't seal up a second time.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Paper gaskets are one time use.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    you can buy gasket material by the roll at nearly any auto parts store. you simply trace it out, and cut.
    maybe use a very small amount of RTV as well with that "make a gasket" roll..??
    gaskets are cheap insurance from leakage or seepage, to re-use.
    Dino soar Thanks this.
  6. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    I just use a paper thin coat of grey RTV. Never leaks and the nuts stay torqued.
    buddyd157 Thanks this.
