RGN LIGHT DUTY
Discussion in 'Ask An Owner Operator' started by mickutzu2011, Apr 12, 2019.
  1. mickutzu2011
    mickutzu2011 Bobtail Member
    16
    So i have an 06 freightliner columbia with a s60 535HP 10 speed with 3.55 ratio. Do you guys think i can pull an RGN light duty?
    Thank you!
  3. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,651
    Oct 5, 2012
    Earth
    Kind of depends on what your tractor axles are rated. If they were rated 44/46,000 you're good to go fully loaded.
  4. mickutzu2011
    16
    Does it matter the steer axle? And i think i have only 40,000 on drive
  5. Tb0n3
    4,738
    9,651
    Oct 5, 2012
    Earth
    The steer is usually permitted at 12,000 unless you have a heavy axle. I've run just fine with 112,000 with a 3 axle RGN. I can't really say if 40,000 is enough. It's right on the edge of permits which will often allow you 20,000 for each axle. Light? No problem at all, I'd say.
  6. mickutzu2011
    16
    Yes light. Nothing over 80,000 GVW
  7. Tb0n3
    4,738
    9,651
    Oct 5, 2012
    Earth
    Only thing to really be concerned about is disconnecting to load vehicles. I don't know about mechanical, but with a hydraulic neck you'll need to keep a 4x6 or 6x6 to bridge the frame and have either a pony motor or a wet kit for your truck.
  8. mickutzu2011
    16
    It's mechanical. Thank you
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    When buying a permit, I have never been ask what my axles are rated for, just how many I had.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    You won’t have any issues pulling a 2 axle rgn around with that truck. Make sure you put a decent set of frame ramps on though if it’s a mechanical neck.
    Tb0n3 Thanks this.
  11. mickutzu2011
    16
    Thank you. I saw there are different sizes of ramps. Do i have to measure my frame or should i made some custom ones?
