Rgn slide outs
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, Nov 21, 2019.
  1. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    Just curious, what the aluminium slide outs you see on AG trailers are rated for? I assume they are rated less than steel outriggers
  3. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    I would have to check what my trailer says but the farther you pull it out the less it is rated for but I have never had a problem with them yet
  4. TripleSix
    133,243
    Had a piece that was 14 wide, 27000k, supported on 4 slide outs only. And they were all the way out. They’re pretty strong.
    pushbroom, D.Tibbitt, Lepton1 and 4 others Thank this.
  5. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    Not the same thing, but... comparing the "strength" of cast iron, like the swing out cast iron outriggers... There is a wide range of cast iron, but typically its considered to be around a 40,000 yield. Some tempers of aluminum can be over 35,000. Doesn't take much more aluminum to make it stronger than the cast.
    Lepton1 Thanks this.
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    What you're actually comparing is the load rating of 2" oak vs the aluminum pullout. I'm guessing the aluminum wins.
    D.Tibbitt Thanks this.
  7. RollinThunderVet
    717
    970
    Idk, I am looking at moving to an RGN. And I seen quite a few of the trailers with the aluminum slide outs(27" each side). Just curious what they rate to, as it seems that if you needed to extend for like a 14w crate, would that be acceptable or a no-no?
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    You're not going to use the pull-outs for a crate. They're for wheels and tracks. Anything that will sit flat on the deck just hangs over, unsupported, usually.
  9. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    How do you figure?
    cke and Oxbow Thank this.
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I've seen a LOT of planks break while the cast iron outriggers were fine.
    Ridlingdj Thanks this.
  11. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    The difference between the cast and aluminum is the leverage applied because of the way the are extended. The swing outs are braced top to bottom the slide outs when slid out don’t have much inside the beam and they can bend easier.
    cke, CharlieK, Oxbow and 1 other person Thank this.
