Ride height
Discussion in 'Volvo Forum' started by Helowrenchturn2, Jun 19, 2013.
  1. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Shop foreman told me the measurement should be taken from bottom of frame rail to the bottom metal part of airbag. Said for my 780 it should be 13 3/4 in. Mine was almost 2 in too high. So I made the adjustment and will see if it smoothed out any
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    The top pf youre frame ahould be lined up with the top of youre rear tire you can measure the airbag from bottom to top it should be between 14.5 and 15.5 inches 15 is ideal
  4. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Then mines gonna be to short. :( story of my life lol. He did say that there were two different sizes of frame rail and when he put the template in it he said mine are the bigger size and then gave me the 13 3/4 measurement
  5. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Ive never had to set up two volvos differently doeant matter the model or the year as far back as 99 the ride height is always the same make sure the top of youre rear drive is lined up with the frame and that should be perfect
  6. RogueX
    RogueX Light Load Member
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    How did this adjustment go? Did things smooth out? Which measurement did you use, and where?
  7. Helowrenchturn2
    484
    140
    Apr 23, 2013
    15 in. Smoothed out pretty good
  8. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    This measurement is for the airbag on the rear drive axle right?
  9. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    The drive axle all the wat in the rear make sure the truck is on level ground and its from the top to the bottom of the base of the air ag
    RogueX Thanks this.
  10. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    had mine adjusted 3 times then found out the leveling valve was sticking
