Ringing sound?!?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Hodginshauling, Jul 2, 2019.
  1. Hodginshauling
    Hodginshauling Bobtail Member
    4
    Hey everyone,
    Hoping to get some insight on a ringing sound my 1994 Ford L9000 8.3 Cummins Quad dump truck is making. We try to do what we can mechanic wise ourselves on the weekend so we don’t have any downtime on the truck.
    It is very high pitch and only occurs when the truck is moving. Doesn’t matter if loaded or not anytime the truck is moving it makes this noise and doesn’t if it’s sitting idle. Ive included a video of the sound.
    Any ideas?
    Thanks in advance.
  3. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Wheel bearings? I'd say thats bearings somewhere. Since it's not when its sitting I'd say drivetrain bearings somewhere. Maybe even the driveshaft, transmission, something going wonky there.
    It also apparently has a dog caught up somewhere in the drivetrain.
    Hodginshauling Thanks this.
  4. Blu_Ogre
    Blu_Ogre Road Train Member
    8,459
    50,495
    Jul 14, 2013
    Out west
    Could something be dragging? Like a hung tire chain?
  5. Espressolane
    18,652
    116,848
    Check the carrier bearing.
  6. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    Bicyclist stuck under neath ringing his bell?
    D.Tibbitt and Blu_Ogre Thank this.
  7. Buck_webb
    Buck_webb Bobtail Member
    7
    Jul 2, 2019
    Wheel bearings would be my guess
  8. Hodginshauling
    4
    Thanks for the feedback. The high pitch whistle hurts my dogs ears, sorry for the barking in the video. My husband said it is in the engine or in that area. He did say he will check the carrier bearing. Thanks again! Will post if we figure it out.
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    If its coming from the engine bay, does it change with the RPMs? If so, could be a pully bearing. AC, alternator, belt tensioners, etc.
    D.Tibbitt Thanks this.
  10. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    Take the belts off and start it up.
    DON'T ALLOW IT TO RUN LONG ENOUGH TO OVERHEAT!!!!!
    That will help locate the issue.
    If the noise is gone, you know it is from something that the belts turn. Alternator, water pump, one of the tensioners, etc.
    speedyk Thanks this.
  11. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    How fast are you traveling in that video?
