Rolling Dirty
Discussion in 'Trucking Accidents' started by mjd4277, May 15, 2025.
  1. Truckers Report Jobs
  2. Chinatown
    Chinatown Road Train Member
    77,549
    182,822
    Aug 28, 2011
    Henderson, NV & Orient
    I saw the aftermath of something similar, but worse.
    Madison, TN a hot asphalt truck turned the corner too fast at a 4-way traffic light. The hot asphalt poured out and filled a car and baked to death a Mother and young son.
    tscottme, Numb, mjd4277 and 1 other person Thank this.
  3. Flat Earth Trucker
    4,297
    16,368
    Nov 19, 2018
    The unfortunate wreck...
    Not even a hundred yards away. :(
    Big Road Skateboard and mjd4277 Thank this.
  4. 201
    201 Road Train Member
    12,726
    26,171
    Apr 16, 2014
    high plains colorado
    My baloney has a 1st name, it's always the brakes. I don't know, looks like skid marks to me. "Brake failure", like the mystery 4 wheelers or deer, if brakes fail, they apply, not no brakes at all, so that is bunk, and I've hauled fill, 10 to 1 they were overweight.
    Flat Earth Trucker and JB7 Thank this.
  5. SmallPackage
    5,765
    18,476
    Dec 20, 2019
    Marion Texas
    If spring brakes apply skid marks. That is why they used to be called “emergency” brakes. Nowadays they are taught to be just for parking. Threadle valves go bad and you have no control at the foot. Hit the peddle and nothing with full air in system. Many brake failures are this. There have been many. No one is taught to pull the knobs out in an emergency because the fail safes are supposed to do it for you. BUT pressure has to be lost for them to work. Pressure is not always lost in these situations.
    201 and Flat Earth Trucker Thank this.
  6. SmallPackage
    5,765
    18,476
    Dec 20, 2019
    Marion Texas
    One of the nice things about the pre-121 brake systems was the Johnson bar was generally plumbed separate from the foot valves so trailer could be operated without exhausting air thru the tractor. Great in emergency. Lock that trailer up. New systems have them tee’d in to same supply line
    cuzzin it, 201 and Flat Earth Trucker Thank this.
  7. ducnut
    ducnut Road Train Member
    2,674
    8,065
    Dec 31, 2010
    SPI
    That black mark is where the tread was rolled under and the sidewall is painting a line. Next offramp you go around, look to see if you can see narrower versions of that mark around the curve, where drivers are on the verge of a rollover. I see them all the time.
  8. 201
    12,726
    26,171
    Apr 16, 2014
    Thanks, I suppose it could have been brake fade too, I've had some scary rides in dump trucks, for sho'.
