Rooftop AC unit
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85COE, May 20, 2022.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Imma do some research and apparently a rooftop RV AC unit needs a 50 amp breaker, that's why a generator is used to run them. You think it would be okay to run it while driving and or idling?
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    Have you looked in the dash to see if the wires for a/c control are hanging out of the harness somewhere unused? If the wires are there already I bet it would be pretty easy to retro the factory air stuff out of another White or some of the Volvo-White-GMC’s that may be laying around into your truck. That’s probably worth looking into at least.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,538
    6,611
    Aug 26, 2014
    I thank it wound would need to be wired directly to the alternator. There are some 180 - 200 amp alternators these days that might do that at idle. Yours will not. I am not sure how they will stand up to that amount of current continual.
    At current fuel prices a generator wound pay for itself in short order over idling the truck.
    KB3MMX and spsauerland Thank this.
  5. BoxCarKidd
    4,538
    6,611
    Aug 26, 2014
    I thank your cab is the same as a Road Boss II. Maybe later but the conventionals shared the same cabs. That gives you a lot more options to look at.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    You're not going to run 50 amps AC on an alternator. When I get close to 20 amps, the voltage drops too much to keep up and the inverter resets. If you try to run a generator while driving, it will probably shut down due to low oil protection activating from the movement of the truck. I have plugged my mini split into the inverter while idling, and dash voltage drops to 12.4 while cooling on a hot, sunny day when my truck AC was not working. It may have eventually leveled off somewhere around 13.1 I'm guessing, but I didn't stay parked long enough to find out. I'm pretty sure it's only a 15 amp appliance.
    BoxCarKidd and spsauerland Thank this.
  7. spindrift
    spindrift Road Train Member
    3,234
    12,914
    Dec 2, 2014
    Texas
    An RV rooftop A/C has a peak load of about 21A. Larger RVs with two A/Cs, microwave, coffee pot and other accessories will have a 50A service.
    KB3MMX, AModelCat and spsauerland Thank this.
  8. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    I don't have any AC controls. It's only Hot/Cold and Defrost options. I'm upload a pic later.
    I thought about putting in a compressor, but wouldn't that require some major work due to belts?
  9. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    So far, the smallest I've found is 11,500w. I'm thinking if I can find a 5k or so, I should be good.
    spindrift Thanks this.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    You just wanting to retrofit your existing A/C or trying for sleeper setup? If just trying to get A/C look into Vintage air that they use in hotrods Vintage Air Builder Series - Vintage Air. @W900AOwner did this with his truck and it is the plan for my 82.
    BoxCarKidd, AModelCat, kranky1 and 2 others Thank this.
  11. spindrift
    3,234
    12,914
    Dec 2, 2014
    Texas
    Very affordable.
    spsauerland Thanks this.
