Rough idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by truckerbangin, Mar 1, 2018.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    I have a Kenworth t600 series 60 12.7 Ddec iv it idles with and abnormal pulse but revs out smooth.
    Also have a Freightliner fld112 with Cummins m11 celect plus idles with a miss revs with a miss but it you hold rpm above 1500 for a few seconds it stops missing revs clean until it drop back to idle and the miss comes right back.
  3. TheDudeAbides
    TheDudeAbides Medium Load Member
    374
    455
    Dec 5, 2014
    San Antonio, TX
    I’d be interested to hear what anyone has to say regarding this, my 12.7 does the exact same thing. Rev the engine to 1200 or so and it goes away. Doesn’t normally do it when it’s cold though (below 60 or so)
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    It’s been a while, but we had a couple 12.7’s that did that, I don’t remember for sure, I think it may have been the fuel pressure regulator/check valve in the back of the head. It may have been the fuel temp sensor or a fuel line restriction. But that was 10 years ago. But they should be easy enough to check.
  5. truckerbangin
    268
    45
    Jan 22, 2013
    Turned out to be the truck needed an over head done and Truck run and idles better than ever before
  6. Rideandrepair
    17,498
    56,733
    Aug 8, 2015
    Thanks I’m sure that’s all that’s wrong with mine only does it on occasion sometimes can make it go away while idling by revving it and resetting fast idle
