Routing antenna cable?
Discussion in 'CB Radio Forum' started by OPUS 7, Feb 26, 2014.
  1. OPUS 7
    OPUS 7 Road Train Member
    1,124
    1,010
    Aug 13, 2010
    404
    I searched,but didn't find a thread on this.How do you guys get a cable back through its original route into mirror perch?
    I see lots of drivers,like me sporting the open wire,smashed into door frame.It looks like crap,and I would like to tidy up.
    Is this something for the professionals?
    My original wire is long gone.It seems impossible to get another cable back into the original dash/mirror.06 Volvo
    Thanks :biggrin_25519:
  3. Picklechips
    Picklechips Light Load Member
    103
    34
    Feb 23, 2014
    Remove the end of the coax?
  4. juanveldez
    juanveldez Light Load Member
    152
    44
    Apr 24, 2007
    Iron Mountian MI
    first you have to take the back of the mirror off. that is a huge pain in the rear trust me. I am personally waiting for it to warm up first so I can do it on my 13 volvo. secondly at least on my truck its a two man job almost cause you gotta take the mirrors out in order to get the back to pop loose then take the back off. after that it is fishing it down through the mirror arms to the side of the truck. after that it is which way do you want to go. again personally I am gonna run mine down through the door to the firewall, then through the firewall under the floor and up through the dash. but like I said I am waiting for it to get warmer, it hasnt been above 10 degrees F for some time.
    OPUS 7 Thanks this.
  5. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    My antennas are Blue Tooth!:biggrin_2552:
    Flatbedder73 Thanks this.
  6. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    That would be da bomb!!!!
  7. rabbiporkchop
    9,688
    6,540
    Feb 9, 2012
    Wapwallopen, Pa
    Volvo VNL780 ran wire up over door and behind refrigerator and under bunk to my amp.
    Then ran phasing harness from amp through rubber grommet in floor under cab to rear fairings.
    How I did mine
  8. MACK E-6
    49,923
    237,268
    Did that require any drilling?
  9. rabbiporkchop
    9,688
    6,540
    Feb 9, 2012
    Wapwallopen, Pa
    I drilled a hole where nobody would ever find it. I pulled out the refrigerator and drilled through under the bunk. Fished my cable through and replaced refrigerator.
  10. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Did the same as rabbi and did noo drilling..I use existing holes from factory..
    Just gotta take the time and look around and see what options are
  11. rabbiporkchop
    9,688
    6,540
    Feb 9, 2012
    Wapwallopen, Pa
