RTLOC16909A info
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by W Bench Farms, Feb 16, 2022.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Have had a fiasco switching my truck over from a 10 speed to 13. Salvage yard sent an 8LL instead of a 13. Been working with them close to 2 months to find another. They have an RTLOC16909A which should be a convertible 9 to 13. I see that there is a kit available for the swap. Anything else that I need to verify? What is actually in the kit? Already have the new shift knob. Don't want to go through these problems again. Just trying to find out everything I need to, and make sure it's what I need before they ship it.
  3. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Air line and a shifter knob is all you need. How in the world did they confuse a 8LL for a 13 speed?
    Roger McG Thanks this.
  4. W Bench Farms
    211
    351
    Oct 16, 2017
    Perfect.
    8LL didn't have a tag on it. I took their word for it, and didn't think to check anything else out. Hooked up air lines and H/L had air when in low range.
  5. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Found this chart that should work.
      File size:
      132.1 KB
      47
  6. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Someone else can verify. I didn't do transmission work at our shop (just everything else). My brother did all that but I know it was just lines and knob.
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    You have to modify your driveshaft length as well. 13 speed is somewhere around 3 inches longer transmission if I remember correctly. FRO 10 speed is 29.93 inches RTLOC is 33.1
    spsauerland Thanks this.
  8. W Bench Farms
    211
    351
    Oct 16, 2017
    I had the driveshaft shortened to fit the 8LL before I knew it was wrong. Hopefully it's the correct length now.
    Smellfunny Thanks this.
  9. Dino soar
    Dino soar Road Train Member
    4,810
    26,922
    Dec 8, 2017
    I don't know what the conversion kit cost but it would be simpler to just buy a whole transmission and put it in I would think.
    If it was their mistake they really should return it and make you whole.
  10. W Bench Farms
    211
    351
    Oct 16, 2017
    They're supposed to exchange the 8LL they shipped for a 13. I had already installed the 8 before I figured out the mistake. Needed the truck, so have been running it while they found another 13. I looked up the kit and it includes the shift knob, which I already have, along with some o rings, valve cover, etc. About $150. Don't need all the parts though. From what I've found, the RTOC is a 13 without the splitter knob installed.
    The 8LL can't be converted, so it has to come out.
    Dino soar Thanks this.
  11. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    You are correct, the RTOC is built the same as a 13speed but the air for the shifter is plumbed as a 9, add a 13speed shift knob and re-plumb it to a 13 and you are good to go. The one's that I have converted to 13's I had to do some work with the splitter to get it working after not being used for years.
