Running a tight schedule
Discussion in 'Questions From New Drivers' started by Lonester28, Apr 10, 2023.
  1. Lonester28
    Lonester28 Bobtail Member
    6
    4
    Jan 27, 2023
    Have a live load at 5:30pm and delivery time is 6am Also it's 300 miles in distance . How would I run my clock to make it in time ?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,968
    19,006
    Nov 1, 2010
    Burnsville, MN
    The 300 miles is no problem in that time frame, but when does your clock start and is it also a live unload?
    If it is a live unload you may not be able to fit it in a 14 hour shift.
  4. Rideandrepair
    17,547
    56,852
    Aug 8, 2015
    What time did the clock start? You’ll need 5-6 hrs driving time available. Otherwise show up to load before 2:00 pm. Preferably earlier. Start out at midnight or earlier with a fresh 14 available.
    kylefitzy and Lonester28 Thank this.
  5. Lonester28
    6
    4
    Jan 27, 2023
    Yeah I could easily knock that 300 miles out in a few hours , Yeah both are live load and live unload . I have most of the day tomarrow to figure out what time to start it but idk if I can make that delivery if I do my 10 hr or try and do a split
    Rideandrepair Thanks this.
  6. Lonester28
    6
    4
    Jan 27, 2023
    It's a pickup tomarrow at 5:30pm but it's a live load so idk hos long they'll take loading and Yeah I was thinking of doing what you said , Thank you for your help I appreciate it .
  7. Moosetek13
    14,968
    19,006
    Nov 1, 2010
    Burnsville, MN
    You can not do a 10 in that time.
    Maybe someone who uses the split can help.
    I would have flatly turned that load down.
    sevenmph, MSWS, austinmike and 3 others Thank this.
  8. Lonester28
    6
    4
    Jan 27, 2023
    Yeah most likely I'll have to talk with my dispatch and try to get that delivery time pushed back by a few hours .
  9. LOTSO
    LOTSO Heavy Load Member
    877
    2,100
    Mar 28, 2023
    Split Sleeper. Do it all the time. Taking a 7-8 hr. break feels a lot less boring than a 10.
    Rideandrepair, lual and tarmadilo Thank this.
  10. Ridgeline
    22,717
    123,104
    DON'T try to figure out the drive time at the speed limit, use 48 mph to figure out how much drive time you need.
    austinmike, Rideandrepair and lual Thank this.
  11. Moosetek13
    14,968
    19,006
    Nov 1, 2010
    Burnsville, MN
    Pushed forward in time, actually.
    But that should have been done before you accepted the load.
    At my company I would have used mac 9 to counter the times.
    Sure, I'll pick up the live load at 1730.
    That would put me at 1930 when loaded, but then I would be shutting down for the night.
    Add in my 12 hour break and I would be driving at 0800 the next morning.
    5 hours of drive time plus one hour of leeway would put the delivery at 1400.
    MSWS, beastr123, gentleroger and 2 others Thank this.
