Running Lights Fuse
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Daycabinit, Aug 23, 2022.
  1. Daycabinit
    Daycabinit Light Load Member
    93
    60
    Dec 11, 2016
    Running lights fuse keeps blowing, the truck only pulls one trailer I’ve gone over all the wires on the truck and trailer I replaced the pigtail still keeps blowing after driving about half hour I was sure it was a worn thru wire but I can’t seem to find it. Any ideas ?
  3. AModelCat
    164,564
  4. tscottme
    tscottme Road Train Member
    I think @AModelCat is right. If the truck has been in use for years, been modified with extra lights or any modification near wiring I'd say a nicked wire or damaged connecter could cause the fuse to keep failing. Did someone add more lights than came from factory or switch some or all lights to LEDs.
  5. Daycabinit
    93
    60
    Dec 11, 2016
    All the same lights for the last couple years there is just the minimum lights on the truck /trailer nothing fancy
  6. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Over the weekend/evening, disconnect truck and trailer, turn on running lights, see if its time only with just tractor first eliminate variables.
