Rusty dif
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Steve62, Jul 8, 2018.
  1. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    so my front dif is weeping oil. I thought it was a seal. Took it in, they tell me my dif is rusty and weeping.
    What is the best stuff to use to seal this up???
    Thanks Steve
    Rockwell 46000 lbs rearends
  3. AModelCat
    164,354
    Where's it leaking from on the housing?
    Sometimes it can be patched with a welded plate if its just one little area that's corroded through. If the whole housing is rough you might be better off with a housing swap. They're not overly expensive from a wreckers. I paid around $1,200 for a complete used drive axle with suspension. A housing alone would probably be less.
    Oxbow, Steve62 and Dave_in_AZ Thank this.
  4. Steve62
    170
    98
    Mar 5, 2015
    Northern BC
    Top right hand side near out put shaft. When looking at it from the rear.
    Oxbow Thanks this.
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If its accessible, use a needle scaler on it to get all the crust off. Then a wire wheel on a grinder.
    When spotless spooge lots JB weld on the area. That will be your easiest and cheapest way to fix it.
    Proper and guaranteed way is to replace housing with non crusty version .
  6. AModelCat
    164,354
    I have heard that JB Weld works but have not tried it personally so I can't vouch for how well it works.
    Oxbow and Steve62 Thank this.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Well I've used it many times and never had a failure.
    The thing is this guy has nothing to loose by not using it.
    Ultimately the only sure and proper way of fixing it is housing replacement like A model said.
    BoxCarKidd, Oxbow and Dave_in_AZ Thank this.
  8. Diesel Dave
    9,604
    32,251
    Jan 20, 2010
    Hesperia, Ca.
    My drivetrain specialist says it normal for it to leak on that particular spot after a few years. I have 402’s and it leaks there so I asked when he was rebuilding my transmission. He told me that’s the thinnest part of the housing. And if you take apart to re gasket, your gonna run into other issues. He recommended to run it until it comes to rebuilding.
  9. Dave_in_AZ
    422,724
    My three favorite remedies listed almost in order LMFAO.
    1) Used parts.
    2) JBWeld
    3) Use it, as long as DOT don't get you, until it's time for a refit or re truck.
    Steve62 and Diesel Dave Thank this.
  10. Diesel Dave
    9,604
    32,251
    Jan 20, 2010
    Hesperia, Ca.
    Mine has been leaking a few drops (you can see when parked) for 10 years and been through countless inspections and only 1 DOT mentioned it only cause he was a former heavy duty mechanic. He never wrote me up, just mentioned where it was coming from.
  11. AModelCat
    164,354
    Its usually where all the salt and crap sits too. I had a set of used 40k Rockwells I bought and they looked great..... until I hit them with a pressure washer and blew a hole through both housings lol.
