Safe haven
Discussion in 'Experienced Truckers' Advice' started by zigstar, Dec 22, 2019.
  1. zigstar
    zigstar Light Load Member
    184
    95
    Nov 6, 2015
    What was the longest trip to nearest truck stop to park?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Usually when there is white line fever and you cannot keep it between lines anymore.
    Coffey and zigstar Thank this.
  4. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    As long as it takes to the nearest appropriate place.
    And it isn't a "safe haven." That's a term for hazmat.
  5. Chinatown
    Chinatown Road Train Member
    77,611
    183,480
    Aug 28, 2011
    Henderson, NV & Orient
    I did 80 miles, but the Elog had a way to get around the excess driving at that time.
    Not hazmat though.
    zigstar Thanks this.
  6. zigstar
    184
    95
    Nov 6, 2015
    I’m not under hazmat load, bad choice of words. I’m getting unloaded 1am, and closest truck stop is 49 miles away.
  7. zigstar
    184
    95
    Nov 6, 2015
    They don’t let you stay on their property.
  8. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    Nah, pretty common. The only reason I mentioned it is because the FMCSA does refer to safe haven.
  9. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    You can drive to the truck stop when unloaded on PC.
    You can start your 10 hour now.
  10. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    And even when you are loaded, now.
    3. Time spent traveling to a nearby, reasonable, safe location to obtain required rest after loading or unloading. The time driving under personal conveyance must allow the driver adequate time to obtain the required rest in accordance with minimum off-duty periods under 49 CFR 395.3(a)(1) (property-carrying vehicles) or 395.5(a) (passenger-carrying vehicles) before returning to on-duty driving, and the resting location must be the first such location reasonably available.
    - List of Proper Use of Personal Conveyance
  11. zigstar
    184
    95
    Nov 6, 2015
    This is Mclane in Manassas Va, I’m doing 10 hrs now, they let you stay before appointment, but after empty was told have to leave. Also my company allows 30 minutes pc each way, and I am 49 miles away so can’t do that.
