Safety Triangles
Discussion in 'Experienced Truckers' Advice' started by TripleSix, Mar 1, 2014.
  1. TripleSix
    133,016
    Was rolling west on 40th street with an oversized Friday. An eastbounder hollered at me on the radio and told me about an accident on my side that had just happened when he went by. A pickup truck slammed into the back of a big truck. I was 30 miles away. He told me that there were no emergency vehicle on scene when he went by and no backup, but by the time I get there, there will be a backup. He also told me of an easy route around it. I thanked him, but I was routed by the state and the only way I could go off route according to the terms of my permit is if HP shut the bigroad down an set up a detour.
    Well, the backup was only 2 miles long. Then I saw it. Big truck sitting on the shoulder. The ICC bumper was mostly intact, but the left side of the trailer axles were knocked off. The pickup was loaded on a rollback. The hood and the engine were laying in the bed. Had to be a fatality. Had to. A driver comes on the radio and says, "I sure hope that driver wasn't asleep on the shoulder." Another driver got offended, "Why does everyone always think that the truck driver is automatically at fault?" I didn't say anything, but I didn't see any triangles, or remains of triangles out. Hence, the reason for this post.
    Rookies and wannabes, let me give you all a heads up: there is a section on the CDL test dealing with those triangles. All trucks are required to carry them and use them. Your CDL handbook will tell you how to place them and how long you have to get them out to place them. You can bet your bottom dollar that the first thing HP did when they rolled up on that accident is look for the triangles. Guess what it means if you don't have them out and someone hits you? Doesn't matter if they are drunk, high or suicidal, you are in deep trouble.
    If at all possible, avoid pulling over on the shoulder of the bigroad or any major hwy. it's the first thing the bloodsucking lawyers are going to try to get you on.
    say for example, you see a car go off the bigroad and on a nature drive. You get out of the truck to help. First thing you do, set up the triangles. CYA!!!!!!! Don't let being a Good Samaritan be the way the bloodsuckers take you down. And they will most certainly try, regardless of your good deeds or intentions. Protect yourself at all times.
    Adios.
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    YUP! Caught hell for saying CAT would out pull Cummins of the same HP today. Can't learn to shut my Rookie mouth I guess. I tried to pull a dead whitetail buck off the L lane to the shoulder and 2 cars came by and hit it and one had sparks come out under it and never slowed down. It's everyman for himself, don't stop to help and if you are a Good Samaritan, someone will get to you for it.
  4. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    The book will tell you on the divided highway triangles must be spaced 25ft 100ft and 200ft. Nine out of ten trucks on the shoulder are not in compliance with the law. When you hit the shoulder you have 10 minutes to get them in place. Next time you see a truck on the shoulder check it out ,see if they are right. By the way on a two lane it is 1 triangle 25 ft in front and 25 and 100 in back. A lot of the times the truck on the shoulder will not even have his four ways on.
    There that's better.
    SHO-TYME, JRTBud87 and TripleSix Thank this.
  5. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    I stopped once with a truck sitting in the granny lane, I asked where his triangles were so I could help him put them out, he said he didn't carry any.
    I carry two sets just in case........
    If anyone noticed that accident in Chattanooga recently where a lady slammed into the back of a broke down truck and was killed, you can see the broken triangles that she ran over before she hit the truck... CYA
    Pumpkin Oval Head Thanks this.
  6. bucksnort
    bucksnort Light Load Member
    69
    39
    Jan 23, 2011
    more like
    10' 100' and 200'
    DoneYourWay and Homemade1959 Thank this.
  7. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    You cant get some drivers to walk 200' to use a bathroom more less walk 200' behind them to set a triangle. I got inspected by an Ohio ST before moving a oversize load and he actually made me open the box the triangles are kept in to make sure they were in there. He said "You would be surprised how many boxes don't have them in there".
    TripleSix Thanks this.
  8. TripleSix
    133,016
    Someone sent me a pic of the accident. It's not very clear but...
    This is was the accident I was referring to on 49. MM298 i40 wb. The pickup truck is in front of the semi loaded on a rollback.the engine and the hood went through the cab and the top of the cab was now at the very front. You can see the damage to the drivers side trailer axles. If this driver didn't have those triangles out, he's in a world of trouble.
    Thats true, and the bloodsuckers will mention that, and the bleeders on a jury will probably still try to award a non driving, drunk 8am in the morning, non driving persons family a settlement. That's why I try to avoid if at all possible, pulling over on the side of the highway unless it's something with the truck that forced me off the road immediately...like a blown steer. Point is, in this situation, if those triangles were out, this driver is already guilty.
  9. rocknroll81
    rocknroll81 Road Train Member
    1,363
    1,005
    Sep 29, 2010
    West Allis Wi.
    What you have to know is the amount of time that the truck was there before being hit, Federal law says within 10 minutes of being stopped, 392.22 (b) (1) as a general rule...
  10. milkman83
    milkman83 Light Load Member
    81
    52
    Aug 30, 2012
    Syracuse, NY
    It's way more than 9 out of 10 not in compliance, from what I've seen. Once in a while I do spot a leo with lights flashing on the shoulder behind the disabled vehicle, and this I wish they would do more of, instead of hiding in the trees or sitting in medians pointing their radars guns at oncoming traffic like they're shooting a pistol. But that's another topic, for another day.
