Schneider choice board team
Discussion in 'Schneider' started by LALA, Oct 26, 2015.
  1. LALA
    LALA Bobtail Member
    Oct 26, 2015
    I am looking to switch from solo to team driving. Does anyone have info?
    LAwastehauler Thanks this.
  3. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    From what I seen. The rates are the same as solo. You have to dead head more, and that will cut into your bottom line.
    LAwastehauler and LALA Thank this.
  4. LAwastehauler
    LAwastehauler Bobtail Member
    13
    27
    Oct 26, 2015
    Los Angeles
    I've never run team but based on information after talking to team drivers, it's eerily similar to a marriage. It takes a high degree of compatibility to make things work out between the two drivers. You would have to determine if the emotion of a daily close quarter relationship, is worth the trade-off for longer runs and newer equipment. Good luck at whatever you decide. Be safe.
    LALA Thanks this.
  5. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    Seems company teaming is more lucrative.
    HorseShoe Thanks this.
  6. HorseShoe
    HorseShoe Road Train Member
    1,494
    2,779
    Jun 29, 2015
    Do a company team position at a different company if you can
  7. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    I know it is hard to get along with someone else 24/7! Heck most of the time I have trouble getting along with myself for 10 hours!
  8. LALA
    LALA Bobtail Member
    Oct 26, 2015
    I'm talking driving team using the choice board vs using the choice board as a solo driver. I'm doing well so far solo but I was looking to team with my brother to make more money.
  9. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Actual team miles will generally be about 1.5 times what a solo does, unless there is a lot of drop n hook. Hard to support 2 families that way unless you both live cheap anyway.
  10. xlsdraw
    xlsdraw Road Train Member
    4,228
    8,695
    Nov 17, 2010
    Lake Alfred, Florida
    It is consistently reported that the shorter runs is where the money is. Can't see how you'd make more teaming.
  11. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
