schneider trucks question
Discussion in 'Schneider' started by blfan2002, Sep 20, 2012.
  1. blfan2002
    blfan2002 Bobtail Member
    23
    Aug 28, 2012
    Does schneider trucks have APU's? If not can you add a power inverter? How does that all work?
  3. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    What they dont know wont hurt em is how I roll. Just make sure you are not hacking anything apart and do a professional job and everything should be OK. I am pretty sure they do NOT have APU's. When I was a co. driver I put a couple inverters in a couple different trucks n they never knew so no problems...
  4. Wayneh74
    Wayneh74 Light Load Member
    91
    26
    Sep 14, 2012
    Greenwood,Ms
    I think there newer trucks have an apu. But I could be wrong
  5. Razororange
    Razororange Road Train Member
    2,709
    25,772
    Dec 20, 2011
    Milwaukee, WI
    They do not have APUs on any fleet trucks. There are a couple hundred with Auxiliary Cooling units that run off the trucks batteries. They were a test to see if the company wanted to use them. They stopped ordering them on new trucks though.
    As for inverters, Company policy is nothing over 180W and no permanent installs. They will install a 400W inverter for drivers who have Sleep Apnea so they have a place to plug in their CPAP machines that run on 120V.
    Modifying company equipment without permission is a good way to end up fired if they catch you.
  6. Wayneh74
    91
    26
    Sep 14, 2012
    Greenwood,Ms
    Ike's new truck had a apu on it in the youtube video
  7. Razororange
    2,709
    25,772
    Dec 20, 2011
    Milwaukee, WI
    After looking at his videos, his Prostar at Butler Transport an had APU. The Cascadia he has on there has the A/C system on it that very few trucks have.
  8. Wayneh74
    91
    26
    Sep 14, 2012
    Greenwood,Ms
    So they are ok with idling? I have been out of trucking about a year so I know everyone was very dead set against Idling
  9. BossOutlaw88
    BossOutlaw88 Road Train Member
    1,451
    352
    Oct 30, 2011
    Cali
    They are about to equip all trucks with ambient sensing technology to stop idling if the outside temp is greater than - 20 and less than 70.
  10. BossOutlaw88
    1,451
    352
    Oct 30, 2011
    Cali
    Fuel is every company's highest expense.
  11. JustinWaterboro
    JustinWaterboro Light Load Member
    84
    26
    Oct 26, 2010
    Porter, ME
    No need since the newer CPAP machines run off the Cigarette-Lighter Adapters...
