Sealed beam upgrades
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gumper, May 6, 2018.
  1. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    I see lots of rigs running around with LEDs in place of the old sealed beams. Has anyone here had much luck with this swap? Any particular brands you’ve had a good experience with? Are they generally plug and play, is there some wiring that needs done? Not going to go out and buy eBay lights since they most often suck. Have some moisture in one of my lights, so as long as I’m changing one I may as well spend the money on something better.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i just saw a story on this on the tv show, Motorweek, yesterday in fact
    Headlight Upgrade | MotorWeek
    you NEED transformers with the headlights you want, either LED's or some other high powered ones.
    you may, or may not be able to do this yourself, and if so, it ain't no 5 minute job.
    good luck.
    if you have moisture, you very well may have a cracked lens or housing( along the seams where the 2 are glued together) . i have "heard" that in of itself, can be about $500 per side. personally, i'd never buy junkyard units either. no way of knowing how good those are.
  4. Cat sdp
    Cat sdp . .
    21,294
    76,122
    Apr 8, 2012
    Orion's Belt
    I have these......
    4"x6" Rectangular LED Headlight, Polycarbonate Lens, Aluminum, Low Beam, 12-24V | Truck-Lite
    They are plug and play.... much better than the bs headlights that kenworth puts in their 4 headlight system.
    The one large probjen is they pack with snow . The headlights are useless when it’s snowing . It was do bad I took them out and ran regular halogens. I reinstalled the led headlights after snow season was over....
    Unless you can deal with this I wouldn’t recommend these headlights......
  5. LoJackDatHo
    LoJackDatHo Medium Load Member
    446
    752
    Jan 26, 2017
    JW Speaker is the best but expensive. Trucklite makes a good one too and they are cheaper. We have the 4x6 heated and 5x7 JW Speaker lights in our two trucks. The road truck has the heated lenses for melting snow off in the winter bc LED lights do not generate heat to melt snow off like halogens or sealed beam. The local truck does not have heated lenses bc if weather is bad it stays in the shed. They are direct factory replacements. No wiring needed. You will be shocked at what you see at night with them. You’ll never turn your brights on again. Got my 4x6 for $216.95 per light. Got lucky and found them on sale. Usually $300 each. I see they are down to $233-$249 now
    Reason for edit: Price update
    Tug Toy, easytopleez33 and bowhunter67 Thank this.
  6. LoJackDatHo
    446
    752
    Jan 26, 2017
  7. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    LoJackDatHo Thanks this.
  8. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    I seen heated headlights in a Kenworth dealer couple weeks ago. I think the price was under $200.00 each
  9. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    When you do the LEDs make sure they're adjusted way too high like all the other jackholes out there running them.
    delta5, Luwi67, Gumper and 1 other person Thank this.
  10. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    They're great if you know how to align them.
    Some knotheads put them in and they're aimed UP like they're hunting squirrels.
    Not a good way to make friends.
    They are BRIGHT. Be kind.
    buddyd157 Thanks this.
  11. LoJackDatHo
    446
    752
    Jan 26, 2017
    Don’t know if I would trust any other heated light but JW Speaker brand.
    bowhunter67 Thanks this.
