Securement for wheeled rack
Discussion in 'Flatbed Trucking Forum' started by fourbugs, Apr 11, 2025.
  1. fourbugs
    fourbugs Bobtail Member
    6
    Apr 11, 2025
    FullMetalJacket and D.Tibbitt Thank this.
  3. FullMetalJacket
    FullMetalJacket Road Train Member
    3,303
    5,500
    Oct 16, 2013
    Vagrant
    Can't take a picture right now, but I carry a rubber ring set for my nursery loads when loaded on rolling cart/shelves. I'm guessing racks are 6/7' tall & weighty.
    Rubber rings that go around wheels & lever bar that lifts shelves up a few inches to slip them under the individual wheels.
    Still put up bars/straps as fail safe, but they pretty much do not move at all.
    CAXPT, Kyle G. and D.Tibbitt Thank this.
  4. D.Tibbitt
    156,974
    That don't look like much fun at all... if I remember , I have hauled some wheeled racks before but I don't remember what I did for securement.. I guess it depends how they are loaded, but if u could maybe get a strap around a group of them to kind of keep them together . Then you may just be able to strap over them and roll... or if you have wooden nailer boards on your flatbed , good time to put them to use and build some chocking
    CAXPT and FullMetalJacket Thank this.
  5. FullMetalJacket
    3,303
    5,500
    Oct 16, 2013
    Vagrant
    Crap, did not catch the flatbed part of your post.
    I am completely inexperienced when it comes to flatbed securement.
    Sorry to confuse the situation.
    CAXPT Thanks this.
  6. CAXPT
    CAXPT Road Train Member
    3,368
    15,763
    Feb 10, 2008
    like @D.Tibbitt says, chocking at the wheel level, front and back, essentially caging them from movement back and forth without hitting each other and the chocking (also header front and back) and strap each tight to prevent the up/down left/right movement, and it can't hurt to do a slinky style looping with straps, through the bars of the second one. For the first, I'd probably have straps front and back pulling them inward.
  7. CAXPT
    3,368
    15,763
    Feb 10, 2008
    Don't feel bad, this type of freight would typically be hauled in a van where all they have to do is use bars to stops it's backward/forward movement, but with flatbed you just have to get a little more creative to figure out how to implement Van style walling on a flatbed. :)
    :banghead:
    201 and FullMetalJacket Thank this.
  8. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    I agree, this would be for a flatbed considered as a $#!+ load, it really should be in a van. You know,,,a lot of work went into making these carts, and if I was the maker, I wouldn't want them on a flatbed for cripes sakes.
    CAXPT, beastr123 and FullMetalJacket Thank this.
