Securing giant tires
Discussion in 'Flatbed Trucking Forum' started by Walk Among Us, Apr 27, 2025.
  1. Walk Among Us
    Walk Among Us Heavy Load Member
    961
    5,266
    Mar 3, 2025
    Fort Worth, TX
    Wheels with tires securement, stacks of 8'10" wide Caterpillar wheels. 8'tall stacks. 29k lbs. Question, do you simply x-strap each stack with 2 straps, or do you add a 3rd strap going straight across each stack?
  3. Walk Among Us
    961
    5,266
    Mar 3, 2025
    Fort Worth, TX
  4. OlegMel
    OlegMel Medium Load Member
    612
    1,030
    Apr 8, 2023
    I would do 3 straps on each. I always over secure than throw minimum straps. if you’re lazy than 2 straps on each stack. 3 straps on first one
    TripleSix, OldeSkool, CAXPT and 6 others Thank this.
  5. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    I see Watt & Stewart trucks all the time,they almost always have 2 straps,3 is good too.
    Albertaflatbed, CAXPT, cke and 5 others Thank this.
  6. Espressolane
    18,667
    116,964
    Always tried to do a minimum of 2 straps as an X pattern, plus one straight across. Seemed to work well. Never had a problem with DOT on it.
  7. 201
    201 Road Train Member
    12,771
    26,275
    Apr 16, 2014
    high plains colorado
    I read, these tires cost an astonishing $42,000 EACH! It takes 36 hours to make one tire. Whatever you do, don't lose one,,:eek:
    The_vett, CAXPT, cke and 2 others Thank this.
  8. OLDSKOOLERnWV
    19,118
    289,130
    You say wheels with tires? As the tires mounted on the wheels and inflated? If so, I would use 3 straps.
    Hauling just the bare tires I use 2 straps in a X shape, and make sure the strap lays down in between the outer lugs so they don’t move. But that’s just me. Hauled 3 loads of them from from Yokohama in Grove City, OH to a company in Bluefield, WV with no issues….
    cke, lynchy, Isafarmboy and 10 others Thank this.
