Self inflation systems.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Intothesunset, Jul 5, 2019.
  1. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    In question is the trailer I drive it is set for 95psi for tires inflation maintaining. Can the setting be changed to 100, or 110 psi?
  3. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    I believe they have an in line regulator to set the tire pressure... It would depend on if that regulator is a fixed or adjustable type... I would think it would be adjustable. But ive never looked that closely at ours so I'm unsure.
    PE_T, Goodysnap and Intothesunset Thank this.
  4. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    I need to find out more. The main box in middle of trailer seems to be some valves and a regulator. 95 psi is just low psi in today's tire use. Tires take more pressure than a wheel is rated for.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    on our "newest" trailers before i had retired, we had the Hendrickson air inflation system. to be honest, we had light(er) loads than many of you guys haul. i wish i could remember the inflation we had them at, but i cannot.
    i would be sure that the system can be adjusted higher or lower to what you want/need, i just personally never bothered to delve into that myself.
    PE_T and Intothesunset Thank this.
  6. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    I think my trailer is the Hendrickson setup.
    One more odd thing is I can not drop bags on the trailer. But I think it's because of the axle legs locking arms things.
    PE_T Thanks this.
  7. buddyd157
    13,582
    34,899
    May 25, 2017
    under a shade tree
    yes, ours had that as well, it is to support the rear of the trailer from dropping to the ground with the weights of the load with the fork lifts. keeping the trailers at dock level,,,,,,,i liked that part of it too.
    PE_T Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I have the Hendrickson TireMaxx Pro.
    Yes it can be adjusted.
    There is a recommended tool to do the job correctly, about $200.
    But basically there are two regulators set 15 psi apart. The back one with the knurled knob plastic cap is the minimum pressure. The front one to the left is the maximum pressure.
    Every 1/4 turn of the 1/8" set screw equals 5 psi.
    So if you are at 95 and want to go to 100 psi. Turn both set screws in (clockwise) 1/4 turn.
  9. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
  10. PE_T
    PE_T Road Train Member
    Hendrickson has several videos on their YouTube channel. I currently have my trailer tire air system deactivated. I want to buy the tool (Target Gauge) to eventually fix mine. Most Utility locations don’t carry the tool, but they can order it for you. There are 3 different target gauge tools, so you have to find out which tool is yours.
  11. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    Made my own adjustment tool.
    If you open the control box, mine had directions for proper procedure to adjust.
    My last trailer pressure was set at 115psi
    17.5 tires.
    My trailer I have now it is set at 100psi.
    22.5 tires.
    Good luck
    Rideandrepair, tucker and PE_T Thank this.
