Series 60 Headers
Discussion in 'Freightliner Forum' started by UnixNerd, Feb 15, 2018.
Thread Status:
Not open for further replies.
  1. UnixNerd
    UnixNerd Bobtail Member
    26
    17
    Feb 14, 2018
    I've noticed several companies selling their high priced, dolled up exhaust manifolds for the series 60. I've only been able to find a handful of articles about someone building custom headers for some off road competition vehicles. Aren't there any off-the-shelf headers for a series 60? As much trouble as they have with cracking exhaust manifolds, I'd think that there would be a better solution available than a hogged out and coated factory designed log. Is the only solution to custom fab your own?
    tommymonza Thanks this.
  3. wore out
    wore out Numbered Classic
    17,184
    212,200
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What are you going to do with the turbo after you install the custom fabbed header
    Oxbow, Hammer166 and Justrucking2 Thank this.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    LOL! That’s what I was thinking! I’m trying to picture this?
    And to the op, there is no benefit to a competition exhaust manifold on a diesel unless you are pushing serious HP. Factory OEM is fine. As far as cracking, no clue on that regarding the Detroit.
  5. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    I purchased and installed a full tilt manifold. I run a 500 +15% program on the ECM, a BW 702 turbo, and a Donaldson pass thru muffler. After the manifold install, I got rid of 150-200 degrees of EGT temp
    tommymonza and UnixNerd Thank this.
  6. UnixNerd
    26
    17
    Feb 14, 2018
    I'm not looking for custom fabricated headers. I can do that myself. My question is are there not any off-the-shelf headers? If not, why?
  7. wore out
    17,184
    212,200
    Jun 5, 2013
    Because a coated Hogged out log holds the turbo better and flows as good as a header. Though wrapping it with header tape don't hurt.
    I realize they bolt small turbos on little cars with a header, for a class 8 truck it isn't feasible space wise. Or strength wise
    Ruthless Thanks this.
  8. UnixNerd
    26
    17
    Feb 14, 2018
    The benefits of headers over a cast iron log are more than just flow. I'll remind you that a series 60 is a 6 cylinder engine. That's 6 tubes. You may not be aware that there are plenty of V8s running twin 92mm turbos (larger than the 171702 on my series 60) held up by 4 tubes. Surely you're not suggesting that using headers would bend 6 tubes over and drop a turbo on it's poor little noggin?
    Cast iron is far more likely to crack than steel or stainless. In an environment that's subject to rapid temperature changes it's far more beneficial to use a material other than cast iron for exhaust.
    Headers can take up as much or as little space as you want. In the case of a turbo, you don't have to worry so much about tuning length since the turbo will be doing most of the work. However, you can spool the turbo quicker by arranging the tubes going into the flange from adjacent cylinders in the firing order to produce a spiral "swirl". You can imagine that when you start arranging tubes from far ends of the engine to go into one side of the of flange that it could take up a significant amount of room. In a "consumer line/non-race" config, there's still a lot of benefit from pairing cylinders 1,2,3 and 4,5,6 and arranging into the flange in a spiral swirl. While not as optimized as the former solution, it's far more compact. If your concern is fitting everything underneath the windshield of the truck, I see no reason not to build a "header-ish" manifold (exhaust ports dumping into a common tube) out of steel or stainless tube. The result would be a far superior product than what's currently offered at nearly half the price. Maybe THAT'S why...There's far too much money to make off of all of us suckers buying up high priced modified factory junk.
  9. wore out
    17,184
    212,200
    Jun 5, 2013
    To compare a working 6 cylinder engine in a class 8 truck that runs across the roughest roads in America to a V-8 trailer queen that makes a living a 1/4 mile at a time is asinine.
    Bending isn't the worry. Cracking is again we are talking about vibration your forgetting that. I'm not big on replacing blown gaskets all the time either. Any one that's ever run a set of headers knows it's common. Getting 6 tubes basically the same length dump them into a common split outlet, even doing the 3 and 3 that's a tall order for room.
    Oxbow Thanks this.
  10. UnixNerd
    26
    17
    Feb 14, 2018
    Anyone that knows anything about fabricating headers knows that blown gaskets are caused by using thin flanges. Anyone that knows anything about metallurgy knows that steel bends and iron cracks. Anyone that has read the rules of this board has read that it's possible to disagree without getting personal.
    Bean Jr. Thanks this.
  11. wore out
    17,184
    212,200
    Jun 5, 2013
    The build one and prove it. I have cracked more than one set of steel headers is all I'm saying.
    Oxbow Thanks this.
  • Thread Status:
