Series60 making engine noise issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Roadking96, Jun 8, 2022.
  1. Roadking96
    Roadking96 Light Load Member
    127
    57
    Jan 7, 2016
    Hello everyone.got 2009 westernstar with series60 14l DDEC 6.it’s getting noise from back of the valve cover.last time doing an overhead the technician found that jakes settings were too tight.after making adjustments on the overhead the noise went away.but after about 15000 miles it came back.roughly 60000 miles on the rebuild and month left on warranty.technician told me if the noise comes back we’ll have to rebuild the jakes on it.i want to know, can this issue occur with bad jakes or something else is going on with the valves or rollers?Truck runs fine and no check engine light.and i am in indianpolis at the moment anybody know good Detroit mechanic in this area please let me know.i want to get second opinion.thanks!
    Below is the link to the video of noise.
    https://youtube.com/shorts/ZVKpxmI7s54?feature=share
  3. Roadking96
    127
    57
    Jan 7, 2016
  4. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like the Jake springs are worn out. Remember that they have what ever the miles were on the them when the engine was overhauled plus the 60k that you ran it after. If the jakes were rebuilt during the overhaul, the springs have failed.
    Rideandrepair and Roadking96 Thank this.
  5. Roadking96
    127
    57
    Jan 7, 2016
    Got million miles on the truck itself.the jakes were not rebuild during the overhaul.how big of job is it to rebuild the jakes on series60?and can i continue to drive it for like another 1500 til i can get it to the house to fix it?
    Rideandrepair Thanks this.
  6. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Never have done it myself, but I don't think it's to bad of a job. You will probably be ok, just don't use the jake and keep an eye on it.
  7. Roadking96
    127
    57
    Jan 7, 2016
    Ok.appreciate it.this gives me some peace of mind lol
  8. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome. I would get it fixed as soon as you can.
  9. Rideandrepair
    17,548
    56,856
    Aug 8, 2015
    The rebuild kits are very cheap.
    Roadking96 Thanks this.
  10. Rideandrepair
    17,548
    56,856
    Aug 8, 2015
    Buy a stethoscope at harbor freight, listen to the valve cover above each cylinder, for changes in sound. No telling where it’s coming from. Might have a loose valve adjuster on the rocker, or a missing nylon button. Buttons coming off is pretty common.
