Setup external air tank
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by eng.moh.4u, Oct 7, 2017.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    I need a help to get the right place in my truck (Iveco trakker) to get an air connection to setup an outside air tank to use when truck stationary (engine running)
  3. daf105paccar
    6,564
    7,294
    Apr 15, 2012
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I would hook it up to the tank with the #3 pointing to the valve.
    eng.moh.4u Thanks this.
  5. 98989
    98989 Road Train Member
    5,991
    6,742
    Sep 14, 2008
    so you want to supply some external source with it? , while truck is parked,
    i would use either connection where you put tire inflating hose, if you need something with better flow and more permanent solution, than would put T point, to one air bottle
  6. eng.moh.4u
    40
    4
    Jan 13, 2017
    So I can make a T connection at any tank?
  7. 98989
    5,991
    6,742
    Sep 14, 2008
    what for do you need air?
  8. eng.moh.4u
    40
    4
    Jan 13, 2017
    This truck load an oilfield unit with a power pack the power pack contain a compressor fitted to its engine (perkins) to supply air to an air tank. This air used for winch braking system. Sometimes the power pack compressor failed so I need to use truck air system in this situation. I hope it is clear.
  9. BoxCarKidd
    4,548
    6,641
    Aug 26, 2014
    Water is going to accumulate in any tank used to supply air. Therefore the tank with the number 3 valve on it is the best choice. Three of the other tanks would allow higher moisture air directly into the air brake system.
