Shell Rotella
Discussion in 'Ask An Owner Operator' started by 1957evinrude, Nov 12, 2018.
  1. 1957evinrude
    1957evinrude Bobtail Member
    13
    Would Shell Rotella 15 W 40 be acceptable to use in a cummins ISX ?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Yes
    It's probably a better choice than delo for isx, considering isx operates at only about 35 psi oil. I read on rawze something about slightly lower psi, shell is good, slightly higher, say ~60 for cats, delo gets the nod. They are both good.
    Cat sdp Thanks this.
  4. Jayfromthenw
    Jayfromthenw Light Load Member
    203
    295
    Dec 26, 2015
    Out West
    My x15 was factory filled with rotella and our company has 55 gallon drum for top ups on tractors.
  5. jt road hammer
    jt road hammer Light Load Member
    160
    51
    Oct 26, 2018
    what is the best oil for 3406b cat motor ???
  6. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,648
    Aug 28, 2009
    Airlie Beach QLd
    any oils better then no oil is my motto it just depends on how you run it, for extremely cold conditions i'd use something a little more suitable for extreme cold such as 0 w- 30 or 5 w - 30 if however you running below I - 40 in warmer conditions 15 w - 40 would be fine.
  7. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    rotella is fine delvac is now my oil of choice but i have bought many of 100's of gallons of rotella without any oil related problems. only issue iv had with rotella is it seems like oil consumption is slightly higher on most engines. witch is not really a problem. i still use the full synthetic rotella in my diesel pickup.
  8. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    I use Delo just because Cummins says to on the frame but I’ve ran Rotella as well. The 5 gal bottles of Delo are like 10.97 at Walmart which is nice if you do it yourself.
    I believe the poster above is correct though, the X15 is on Rotella.
    Honestly I think it all comes from the same well/pump anyway. lol. Slap a sticker on it.
    Edit: 10.97 per gal but they do have the 5 gal jugs.
  9. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,162
    Jun 3, 2018
    Rotella is fine for it. It's a good oil .I run the semi synthetic 15 40 in my pickup and Delvac in my series 60. No issues yet.
  10. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Just FYI. I use rotella in cat and it stinks through blow by. I can walk up to fellow truckers and say “you use rotella don’t you?” They say “how you know that?” I say becuase “your truck blow by stinks”
