Shifter spring broke?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Al^*, Dec 21, 2012.
  1. Al^*
    Al^* Light Load Member
    152
    105
    Jun 5, 2010
    Kingsport, TN
    My shifter suddenly has no resistance moving side to side. I assume the spring in the top (shifter housing) of the trans broke. It doesn't "spring back" to the center position like normal. (13 speed RTLO16913A). It's not a major issue while driving, but I would like to get it fixed.
    1. Where would be a good place to get this fixed?
    2. Can I replace the spring myself easily through the floor opening?
    3. Could something other than that spring breaking cause this?
    Thanks in advance for any advice.
  3. aktundratugger
    aktundratugger Light Load Member
    126
    32
    Feb 10, 2012
    up on the hill, Ak
    how many miles on it ? a new shift tower is not very expensive. just a thought
  4. olpa77
    olpa77 Light Load Member
    72
    15
    Apr 9, 2011
    Springs are an easy fix. Take the boot off from in the cab and they are right there. You may get lucky and just had one pop off. Unfortunately its probably more than likely broke. However, if thats your problem it's an inexpensive fix. I had this problem once and a spring corrected the problem. The dealer told me if the spring was not the problem it could be a synchronizer, not sure on how true that is though.
  5. Al^*
    152
    105
    Jun 5, 2010
    Kingsport, TN
    Thanks. What I'm worried about is having to work on it one-handed through the little floorboard hole. Especially with the shifter assembly itself about a foot below the floorboard.
    600K. Thanks, I'll have to check on the price, but hopefully I won't need one.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    The spring in the shift tower is just for slop in the tower itself. It has nothing to do with the spring plunger for the side to side resistance when selecting reverse or low. This spring loaded plunger is on the shift fork inside the transmission. The whole shift bar housing has to come out, which may mean the whole transmission if there is a clearance issue. Not something for a DIY'er. The plunger may be stuck or broken spring. Either way, you can still drive it.
    Loudmouth Thanks this.
  7. Al^*
    152
    105
    Jun 5, 2010
    Kingsport, TN
    Yes, after a little research (illustrated parts list and service manual), I know the spring and plunger you're talking about, in the low/reverse shift yoke.
    You know a good shop to get it fixed, anywhere in the midwest, south, or northeast? Can a KW dealer fix this competently?
    Thanks
  8. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    you can drop a new shift tower on it and fix it yourself....quick easy job...you could also put a backwards top plate on instead of the factory one. this is nice because high gear is on the dash instead of between the seats...
  9. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    A shifting tower will NOT solve your problem. As stated earlier, your problem is in your top plate, and may require transmission removal to repair depending on clearance issues. Any competent shop can perform this repair for you.
  10. Al^*
    152
    105
    Jun 5, 2010
    Kingsport, TN
    I'd never get used to that. :biggrin_2559: Besides, I like having the shifter where I can rest my hand on it in top gear. Might be an advantage in a team truck, though.
    But as was pointed out by Heavyd, the spring in question is the one mounted in the low/reverse shift yoke, not the spring in the tower.
    I've pretty much decided not to do it myself, so now I'm just trying to figure out a good place to have it done.
    Thanks.
  11. Al^*
    152
    105
    Jun 5, 2010
    Kingsport, TN
    Thanks, would you consider a KW dealer to be a competent shop?
