Shifting
Discussion in 'Peterbilt Forum' started by BennyWest, Jun 8, 2019.
  1. BennyWest
    BennyWest Bobtail Member
    4
    My 387 gets stuck between the take off gear and 1st gear after I stop.it won't drop past 1st in order to take off. The shift arrow flashes. Anyone have any idea on what could be the problem. Just put a brand new isx in it only has 10000 miles on it. When running no slip or anything
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Sounds like a programming issue. Or a communication error to one of the many PCU modules in modern trucks.
    But just a guess.
    Puppage Thanks this.
  4. Blu_Ogre
    Blu_Ogre Road Train Member
    8,459
    50,495
    Jul 14, 2013
    Out west
    A common issue is the "XY shift plate" basically the thing that changes the gears.
    May need adjusting or replacement.
  5. Dparkersr
    Dparkersr Bobtail Member
    Did you get your problem fixed?
  6. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    Check the air filter on the transmissions air regulator.
