Shoot me straight
Discussion in 'CB Radio Forum' started by awakened, Feb 18, 2016.
  1. awakened
    awakened Bobtail Member
    21
    7
    Jan 24, 2016
    need a suitable setup. 100 dollar budget. Thanks.
  3. Diesel Dave
    9,630
    32,489
    Jan 20, 2010
    Hesperia, Ca.
    Hand held portable C.B. radio, for that budget. Add fifty dollars more and you can get a better set up. Cobra 29 and a Francis antenna.
  4. Diesel Dave
    9,630
    32,489
    Jan 20, 2010
    Hesperia, Ca.
    Try Craigslist or even Ebay. You might get lucky.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Sometimes pawn shops have "big", as in size, radios for cheap.
  6. volvo244t
    volvo244t Road Train Member
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    What's it going in? That makes a difference.
    For the radio, pick up a Uniden PRO 520XL. The best of the cheap compact radios, bar none.
    Antenna will depend on application.
  7. awakened
    21
    7
    Jan 24, 2016
    Thanks guys, prolly be one on a freightliner cascadia, may be willing to up budget 100 dollars to to buy a good setup
  8. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    For a $100 budget, go to a TA truckstop by the end of February 2016 and buy the Cobra 19 on sale for 40 dollars. Next buy either a Francis CB25 4 1/2 foot antenna or a Firestick 5 foot antenna for a single antenna setup. Finally, buy a length of RG58 coax that will connect the radio to the driver's side antenna mount and bypass the factory cable setup. Ignore anyone who tells you that you need 18 feet of coax because you don't. Shorter lengths of coax have less signal loss and that is a very good thing.
    .Now if you can up the budget, use the above but substitute the Cobra 29 Classic on sale for $80 instead of the Cobra 19.
    .For short lengths of coax the performance difference between RG58 and RG8 is minimal.
    jammer910Z and darthanubis Thank this.
  9. volvo244t
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    With a Cascadia, if you can't find at least a 5.5' Francis, don't bother buying a shorter antenna. The 5.5 Francis is the shortest antenna that will work decently on a bird perch mount on a Cascadia. If you can, get to Bob's CB shop in PA (I-80 exit 70) and pick up a 7' Firestik. That's the best antenna you can put on these trucks. Get the stainless steel mount he sells for that truck as well. The Wilson one the truck stops sell is overpriced junk.
