Short Runs
Discussion in 'LTL and Local Delivery Trucking Forum' started by Ricco1689, Jul 9, 2019.
  1. Ricco1689
    Ricco1689 Bobtail Member
    42
    32
    Apr 19, 2017
    NY
    Do these even exist in LTL (linehaul) ? Over 20 years behind the wheel, 15 of it off and on gas tanker. Ideally a run to get back by early am say 3-4 o'clock everyday
  3. Digman943
    Digman943 Medium Load Member
    435
    1,071
    Mar 17, 2016
    Fedex Freight has very short runs with dock time in the Chicagoland area. Hook set, drive less than 50 miles to hub. Work dock 4-5 hours, sometimes less. Hook set and drive back to your home service center. Usually around 8-9 hour day. Sometimes you can get back in under 8 hours. When I get stuck with one of these garbage runs I’m typically in my car headed home between 4-5 in the morning.
    jmz and Ricco1689 Thank this.
  4. DTP
    DTP Road Train Member
    1,281
    2,709
    Dec 9, 2014
    I’m sure there may be one out there somewhere, but linehaul runs are typically a 10+ hour day between your route and some have you work the dock.
    Ricco1689 Thanks this.
  5. MACK E-6
    49,980
    237,825
    Tough to really call it a garbage run if you’re back and gone before it would be time to send you out somewhere after swapping trucks to sort and segregate for 3-4 hours.
    FlaSwampRat and Ricco1689 Thank this.
  6. jmz
    jmz Road Train Member
    1,208
    2,858
    Mar 9, 2018
    Great Plains
    Try working the dock for 5 hours overnight then look at the paycheck at the end of the week and see if you still find it tough to call it a garbage run.
    Cardfan89, McUzi, FlaSwampRat and 2 others Thank this.
  7. MACK E-6
    49,980
    237,825
    Thankfully I don’t have to. ;)
    I was glad when I could get the hell out of dodge before they pulled some crap like that.
    Ricco1689 and x1Heavy Thank this.
  8. Wileycoyote1911
    Wileycoyote1911 Bobtail Member
    19
    46
    Nov 20, 2018
    We got one at our barn that pays 199 miles each way. Driver hooks set, leaves at 19:30, arrives at terminal at 22:45, breaks set and hooks departure set. Leaves around 23:15 and arrives at home terminal at 2:30. It’s our retirement run and actually pays pretty well with all the breaks and hooks that you get paid for.
    dennisroc, Digman943 and Ricco1689 Thank this.
  9. dennisroc
    dennisroc Road Train Member
    1,753
    1,257
    Oct 9, 2013
    Anjung-Ri, South Korea
    Sounds like a good job, do they hire new CDL grads ?
  10. Wileycoyote1911
    19
    46
    Nov 20, 2018
    They require 6 months of experience. You can check out SEFL.com for job listings in your area. More than likely you will have to start P/D and try to get a line run when one pops up. Like with most LTL jobs it goes by seniority and a run like I posted about at our barn stays with senior driver. That’s why we call it the retirement run.
    dennisroc and Ricco1689 Thank this.
  11. Cbp
    Cbp Bobtail Member
    23
    36
    Mar 14, 2016
    Yeah, Estes has these also at most terminals. Usually less than 400 miles, some as little as 6-7 hours a night. Some with dock work some without.
    Ricco1689 and dennisroc Thank this.
