Short wheelbase winter issues
Discussion in 'Canadian Truckers Forum' started by CbarM, Mar 18, 2013.
  1. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    Hey guys, I am curious if a short wheelbase tractor is harder to steer on packed snow n ice then a longer wheelbase is. I just got goin with my cabover 192" WB haulin crude n maybe I just dont have the front end loaded up enough. I am having to take most corners in 2nd or 1st when loaded otheerwise it slides easily. Logic tells me that a longer wheelbase is better for slippery conditions, but this is my first experience in winter with a truck this short...
  3. Sarabeara
    Sarabeara Medium Load Member
    528
    129
    Nov 6, 2012
    Ummm - not trying to hi-jack you CbarM, but hey! Did you remember the photo of this unit you're talking about? I'd really like to see it!
  4. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    Lol...I tried but it said they were to big. Text me n I can send ya some. This truck has gotten alotta compliments already n even had a couple handshakes from a couple of pretty impressed guys!!
  5. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    Go into paint and resize them.
  6. CbarM
    894
    247
    Jan 17, 2011
    Irvine, AB
    Hmm...still cant do it...grrr
  7. Hammer166
    7,582
    27,646
    Aug 18, 2007
    ~8600+' and loving it!
    Yeah, here is why: A longer wheelbase gives the front axle a much longer torque arm, allowing the steers to more easily overcome the friction of the fifth wheel. So keeping the fifth wheel well lubed (or installing a teflon plate,) is much more important on short wheelbase trucks. The longer trucks do have more resistance to rotation, which does reduce the benefits of the longer arm; but overcoming the fifth wheel friction is the dominating factor in what you're asking about.
    25(2)+2 Thanks this.
  8. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    I was gonna say, grease your 5th wheel but he already said it.
  9. Sarabeara
    528
    129
    Nov 6, 2012
    Goes to show you what I thought! I thought it was his center of gravity. I never thought about the 5th wheel! I'm always learning!
  10. Sarabeara
    528
    129
    Nov 6, 2012
    OK.. Right click the unopened picture, and a menu will open saying "Open with" and click on Paint.
    Once its opened, look at the top - close to the left side and click on resize. Change the horizontal, and the vertical numbers to 50, and then hit"ok" at the bottom.
    Save the file with a new name if you don't want to lose the original size. And you should be able to upload this file to this forum. If the file is still too big, repeat the process until its within the file size allowed. :D
  11. JayTee
    JayTee Light Load Member
    248
    151
    Feb 14, 2013
    Like he ^^^ said. Also, if you have the room try and slide your 5th wheel forward and max out the weight on the steers. Remember if you get crossways to the tune of 5 degrees it's gonna feel a lot more out of control than it will with a long wheelbase.
