Short Winch Bar
Discussion in 'Flatbed Trucking Forum' started by Lawdog71, Nov 24, 2018.
  1. Lawdog71
    Lawdog71 Bobtail Member
    45
    41
    Jun 9, 2015
    Thatcher/Tremonton UT
    I've been running a step-deck this past month and have slight difficulty winching straps on the lower deck portion. Anyone know where I can get a shorter winch bar? Or any other suggestions.
    /scott
    D.Tibbitt Thanks this.
  3. JonJon78
    JonJon78 Road Train Member
    7,239
    43,002
    Jul 1, 2018
    I like a shorter bar so I just simply cut mine down to my liking with a saw. Not sure how short your looking to get it but I only cut around 10 inches off mine, works great for me.
    Nothereoften Thanks this.
  4. Lawdog71
    45
    41
    Jun 9, 2015
    Thanks JJ....I'll order 36" cut-off about 10"....thanks.
    JonJon78 Thanks this.
  5. D.Tibbitt
    156,933
    I use a ratchet bar when i pull a step deck, saves time from taking bar out after every click
    Klleetrucking Thanks this.
  6. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    There's a ratchet insert for the winch available, the name escapes me at the moment.
  7. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Silver Cap?
    I wouldn't cut the bar shorter. You want to keep the leverage. A ratcheting winch bar would be cost effective.
  8. Klleetrucking
    378
    346
    Dec 11, 2010
    S.C.
    This is close but there was one that inserted into existing winch transforming it into a ratcheting winch. They were about $35 a pop iirc.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    I ran a lo-profile, trombone, step deck for quite a while... I know the pain. I had the perfect combo tool for that. It was a ~2 foot long, 1 inch diameter, six-sided, solid bar; especially useful on the drop-deck winches when the load was wider than the trailer (which was... always).
    It also worked great for slipping through wheel holes and then hitting the end with a hammer to loosen frozen brakes (no crawling under trailers).
  10. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Quick winch.buy the attachememts and weld them the winches
  11. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Those ratchet winches are the bomb. But they don't hold up very well in the weather.
    Pack spares if you go that route.
    I don't know how you would cut the bar shorter unless you never use chains and binders. Or pack a spare. They're certainly cheap enough.
    cke Thanks this.
