Should I get an eld?
Discussion in 'Ask An Owner Operator' started by nitetride379x, Aug 22, 2020.
  1. nitetride379x
    nitetride379x Light Load Member
    60
    23
    Jul 30, 2020
    Would you recommend being eld compliant or not as new own op
  3. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    Depends on what you plan on doing with the truck.
    I wouldn't unless I had too. But that's me.
    We don't have em where I'm working now.
    nitetride379x Thanks this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Some more info would be helpful here. We're not mind readers. Details? Local exempt 100 air miles (soon to be 150 at end of September)
    There really is no in between you are compliant with 2000 or newer or run 1999 or older if you still want paper.
    jamespmack Thanks this.
  5. bad-luck
    bad-luck Road Train Member
    3,465
    6,391
    Nov 16, 2013
    Baltimore, Maryland
    You haven't supplied enough details. If your tuck is not eld exempt and you don’t have an eld, then you will face big fines and be put out of service until you are in compliance. If you live in or run to California then you need truck thats in compliance with their emissions laws which will be an eld required truck.
    If you have the choice between a truck that can legally be eld exempt then in my opinion I would choose being eld exempt
    Brettj3876 and rachi Thank this.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    My answer is depends.
    feldsforever and Brettj3876 Thank this.
  7. nitetride379x
    60
    23
    Jul 30, 2020
    Sorry, yes for clarification I meant eld compliant truck thought that was implied
    Brettj3876 Thanks this.
  8. nitetride379x
    60
    23
    Jul 30, 2020
    On?
  9. nitetride379x
    60
    23
    Jul 30, 2020
    Never mind that question too many factors
  10. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Why is it even a question? Running paper is the same as running an ELD if you plan on running legal. If you aren't planning on running legal, you need not be in the business anyway.
    HighCountry Thanks this.
  11. jamespmack
    I have a 2000 truck, built with a 1999 engine, but currently has a 1994 block built to 2000 specs. Think i can fly?
    :D
