Should I replace the air compressor soon?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 4noReason, Dec 19, 2024.
  1. 4noReason
    4noReason Road Train Member
    2,392
    752
    Nov 29, 2012
    do you think I'll need compressor soon? my fitting was leaking it was leaking oil and air. should I replace it soon or wait till summer. freightliner columbia 2026 12.7 60 serious. 880k miles
  3. Big Road Skateboard
    7,068
    40,044
    May 2, 2021
    Personally, I would plan on it soon to avoid a breakdown OTR
    Rideandrepair and 4noReason Thank this.
  4. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Where is the oil coming from. Is it from the air compressor or is it up stream from the compressor? Look in the air feed line to the compressor for oil.
    Is the air pressure in the truck OK? How much oil is in your air tank. Do you have oil in the governor?
    At the age and mileage, you plan to keep truck? If yes. It's a good idea to replace compressor. But that may not be the problem.
  5. bjytech
    bjytech Light Load Member
    245
    222
    Nov 9, 2013
    If you are seeing that much oil at that valve from the air system when was the last time the air dryer was actually serviced? even if your compressor is on its way out and pumping oil the dryer should still catch most if its in good working order.
  6. Rideandrepair
    17,540
    56,829
    Aug 8, 2015
  7. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    If you have engine oil in your air lines, than your air compressor is worn out.
  8. 4noReason
    2,392
    752
    Nov 29, 2012
    lmfao
    2016. imagine that
    Rideandrepair Thanks this.
  9. 4noReason
    2,392
    752
    Nov 29, 2012
    ok so I'll get ready to change it soon. thx u
  10. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Your welcome. Fyi, if you have an air dryer with a changeable filter, it should be changed once a year.
    4noReason and Rideandrepair Thank this.
  11. Rideandrepair
    17,540
    56,829
    Aug 8, 2015
    I’m wondering what kind of dryer it has. Older AD9 supposedly catches most oil without problems because of its size. Newer expensive spin on type are supposedly coalescing. They’re made to catch oil. I imagine either one can get full and not work properly. The spin on type is easy to change. My new compressor pushes oil. Bendix claims some oil is normal. I drained the tanks, took SS hose off at compressor and poured some air line conditioner into the SS hose, changed my whole dryer, AD9 are cheap. Maybe try that, and change the filter. You probably have the spin on type. Regardless 800k miles is a lot of miles. Either way, if changing the compressor, replace governor with brand new, not reman, keeping old as a spare. new air dryer filter, if not a whole new dryer.
