Shuts down in rain
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CMK, Mar 22, 2024.
  1. CMK
    CMK Bobtail Member
    Jun 19, 2018
    ALABAMA
    2008 Freightliner cascadia only shuts down when it's raining and won't restart until dry, what could cause this problem?
  3. gerardo1961
    gerardo1961 Road Train Member
    1,750
    616
    Feb 21, 2010
    Miami
    i have 1 time a similar problem ,water was going to the fusebox{only when was raining}
  4. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Check your windshield gasket. Cascadia has a lot of complaints about water leaking around the windshield. Then it soaks the electrical connections and fuse boxes mounted motor side of the firewall.
    Check the truck clearance lights for leaks also.
  5. CMK
    CMK Bobtail Member
    Jun 19, 2018
    ALABAMA
    (Check the trucks clearance lights for leaks also). Can you elaborate more on this please?
  6. xsetra
    5,195
    7,146
    Aug 21, 2011
    The cab marker lights above the windshield. The gaskets or caulk might allow water to leak inside.
    CMK Thanks this.
  7. Toey84
    Toey84 Bobtail Member
    16
    5
    Dec 30, 2020
    Bakersfield CA
    Also make sure you do not have any holes on your front cowl, this is right under your wipers. Also make sure you have the hoses attached to cowl that divert the water from your electrical/fuse area.
  8. Ridgeline
    22,721
    122,976
    Proper fix is to have the windshield removed, reinstalled and resealed properly, this still happens with every Daimer truck I buy.
  9. Rideandrepair
    17,534
    56,817
    Aug 8, 2015
    Have you tried to get a code when it shuts down?
