Sizing up turns.
Discussion in 'Experienced Truckers' Advice' started by stryker5673, Jan 10, 2015.
  1. stryker5673
    stryker5673 Bobtail Member
    36
    20
    Dec 14, 2014
    Hey guys, I need some turning advice.
    I've been making turns a bit wide and some a bit short. Mostly wide. I really want to tighten those up...any tips?
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Everything from tandam settings, turn radius and wheel base of tractor, hell even road conditions can change your swing. One word, time. Seat time is the only thing that will change your turns.
    Hammer166, kewphotog and stryker5673 Thank this.
  4. nicknack
    nicknack Light Load Member
    220
    142
    Aug 3, 2013
    Mirrors, mirrors, mirrors
    JReding and stryker5673 Thank this.
  5. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    Keep the turns wide. Once you start shaving your turns is when you'll start bumping curbs and clipping poles. But like streetbeater said, it really depends on your rig, tandem position, and whether it is a tandem axle or a split tandem.
    But a general rule of thumb, for right turns, stay straight until the trailer tandems meet where the curb/shoulder begins to curve. That's what they taught me back when I learned to drive a truck 19, almost 20 yrs ago.
    stryker5673, misterG and Montgomery Thank this.
  6. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    It won't be long,...and you will be able to tell easily how wide you have to Swing to make a turn.
    stryker5673 Thanks this.
  7. Tall Mike
    Tall Mike Road Train Member
    7,613
    36,288
    Aug 20, 2014
    New York State
    keep swinging wide..
    take as much room and time as you need to make the turn without bending up equiptment (or anything else)..
  8. misc
    misc Light Load Member
    183
    133
    Mar 18, 2010
    Like everyone else said. Don't worry about tightening up your turns, they'll tighten up on their own as you gain time in seat.
    One day you'll look out the mirror and realize the trailer is hugging the turn perfectly with no apparent effort on your part.
    That said, I always take turns too wide if I can't see what the trailer is doing due to darkness, etc.
  9. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    No matter what you do, always, always ALWAYS use ALL the space available to you. Every time. You've seen the crumpled guard rails on the inside of exit ramp curves? That's from drivers shaving their turns. Don't be that guy.
    stryker5673 and BROKENSPROKET Thank this.
  10. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    You can't turn "too wide". You can turn "too short". I'd be willing to bet turning incidents almost always occur where the driver had oodles of room and didn't use it.
    Learn to drive the trailer. By that I mean steer the tractor to put the trailer tandems exactly where you want. It takes "practice".
    You can use "laned" two L lane turns to evaluate. Try to make the trailer track exactly in the middle of the lane all the way around.
  11. Tall Mike
    7,613
    36,288
    Aug 20, 2014
    New York State
    boy you got that right !!!
    we already have enough of those guys... :confused1:
